What is the accurate color? I have seen many with a light gray, but recently saw a couple of sets refinished in silver. Thanks.
Scott H.
1969 Coupe LtWt
1973.5 911T
Scott - do a search for soldier grey. I'm about to paint another set and will use soldier grey again except I plan to hit it with a flat afterwards as the soldier grey is satin. It's the closest match I can find after experimenting with several greys from several brands. Also, I had a local powder coater do some test swatches for me. They had one grey that was real close but after they treated with a flat it changed the color completely.
_B
Sent from a pay phone
888888 eL, Oph'eL'ia
Instagram: werk_crew
www.werkcrew.com
www.werkcrew.tumblr.com
www.handofwinter.tumblr.com
That's right - Soldier Gray! Thanks Bob. I believe that I found an excellent match at the local hardware store, but just wanted to double check. Those lenses are going to look great on my car.
Scott H.
1969 Coupe LtWt
1973.5 911T
I have been looking for the correct headlight paint color. Both Soldier Grey (#7926) and Stone Grey (#7926830) are no longer manufactured. I looked at Ford Titanium Grey from another post and that looks way too dark from an on-line paint sample.
Any more suggestions? (I used the 356 engine fan grey on my 356 but I think that that is a little light)
Jim Villers
Virginia Beach, VA
1961 190SL Mercedes, 1965 230SL Mercedes, 1965 356C Porsche, 1971 MGB, 1967 911 Chassis #305119
I've used L472 Beige Grey (sorta greenish tint) as well as L345 Light Grey on VW & 356 headlight buckets,
available from VW restoration suppliers. Bucket resto is common, so why none of them offer the exact color is
a mystery. Krylon Satin Pebble and Satin Stone Grey are also close to Hella grey.
Russ
ESR # 1537
'62 356S Notchback Hotrod
'67 S Das Geburtstagsgeschenk
'68 T Targa Sportomatic
'68 L SW Targa Sportomatic
'70 914/6 GT
I posted this a LONG time ago, but will post again.
I had a NOS bucket color matched using a spectrograph at the local paint store - turns out the color formulation is identical to Ford Falcon Titanium Gray. I still have a quart in PPG at home and will post the formula.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
