Results 1 to 10 of 13
Thread: need to emboss VIN on replacement ID plate
    So I sprung for the Aase replacement VIN plate for my 69T, the plate for which was lost by a PO. Any suggestions for how to best imprint the VIN into this thing? It has the correct "911T" etc on it, just needs the car's individual VIN. I would like it to look correct.
    I'm picturing using a set of number dies like in the link below, and pressing or tapping the numbers into the plate. Obviously want it done right, and am not sure of the font or size.
    http://www.amazon.com/Letter-Number-.../dp/B0006IY52U
    Sep 2006
    Maryland
    I wonder if this is something Porsche would do if you provided documentation. I know in some states even removing the VIN in the first place isn't legal.
    I'm sure the laws vary state to state, but how do you handle a lost or damaged VIN plate. Plates are removed all the time during a restoration, doesn't mean its legal. Its a sticky situation, on the 356 registry advertising the sale of number stamps or restamping services is prohibited.
    Rob Abbott
    larryg57
    Oct 2008
    Greater fly over states
    Try this. German number stamps with close to the original font.
    http://www.samstagsales.com/kukko.ht...pinglettersets
    We've seen plenty of examples of poorly done restamps...
    1) Look through this thread for some good examples of originals (example attached)
    http://www.early911sregistry.org/for...ad-911S/page47
    2) See if you can study a real-life example and get the precise height of the stamp
    3) Go slow and practice on another piece of thin aluminum
    http://www.ehow.com/how_7391814_stam...-aluminum.html
    4) Keep us posted (and get the right rivets, too!)
    Peter Kane
    '72 911S Targa
    Senior Member PeterM1965's Avatar
    Jan 2010
    Scarsdale, NY
    Based on the fact that the VIN number fills the space alloted, and that they were stamping many of these, I would guess that the punch dies were held in some type of device. I would try to take a solid block of plastic about 3/4" thick X 3" high X a little wider than the VIN box and drill holes through it to hold the dies. (see rough illustration below) Do this on a drill press so that you can control the positioning of the holes. Then you will not have to fumble with lining up the numbers and making sure that they are square. You can see in actual VIN stamping there is a certain amount of skewing and jumping baselines. Of course to do this you will need more than one set of punches since most VINs have duplicate numbers.
    Quote Originally Posted by PeterM1965 View Post
    This was my thinking, that this will need some sort of typeset device. The DIYer in me says to get creative and tackle this, but I wonder if I will be better off finding a professional to do this, as I only have one shot at it (these replacement plates cost $275 + shipping from Aase...).
    Yes, I can see how folks would approach this topic carefully. In this case, where the titling and provenance of the car isn't a matter of question, and it's simply a matter of a removal ID point having been lost, I think I am on safe ground. In related threads here and on Pelican, the laws I've seen quoted from statute appear concerned with cases of possible changes of the VIN.
    Quote Originally Posted by super9064 View Post
    Atlanta, GA
    FWIW, 22 years ago I ordered a new VIN from Porsche for my 73S bc I did not like how dirty the original was. I am sort of anal like that. Anyhow, it was no big deal then and they just sent me the new one that looked exactly like the old one. I never got around to install the new one bc I was not sure about how to do the pop rivets properly.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Jul 2008
    South Florida
    The factory likely used a sequential die press to stamp the lot needed for production, not one at a time.
    Why not do as Mark suggests above and send it to Porsche? Another alternative is a trophy shop or jeweler.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Quote Originally Posted by Bullethead View Post
    Yes, that is what I may do. Someone who has experience with this type of work. Although this does not look like rocket science.
  1. Replacement pressure plate advice
    By ajwans in forum Technical Info
    Last Post: 07-25-2013, 10:09 PM
  2. Replacement seals
    By laketrash in forum Technical Info
    Last Post: 06-08-2012, 10:57 PM
  3. H1 replacement parts!
    By kenikh in forum Technical Info
    Last Post: 05-19-2010, 08:50 AM
  4. ID plate in trunk stamp/ emboss?
    By TRE Cup in forum Technical Info
    Last Post: 12-18-2006, 11:56 AM
  5. Pan replacement-FYI
    By tfmcmahon in forum Technical Info
    Last Post: 03-08-2006, 05:38 PM
