Thread: Door brake mount repair
    Need some advise on how to repair a broken door brake mount.
    I have read that this is a common problem on early 911s. The door brake mount sheet metal has come loose and the door brake is not working anymore. Someone told me that there used to be a repair kit available which consists of a pair of metal plates to "sandwich" the original sheet metal mount from the outside and inside of the door frame. Anybody knows if this kit is still available and if so where to get it?
    Thanks much in advance.
    C. Marx
    Jun 2009
    West Hills, CA
    Performance products used to sell that kit.
    It's not a repair though, it's a patch job.
    To repair the door properly it needs to be removed, and then the door cut open. welded and
    painted.
    Espo
    75 911 SCRS
    Thanks, Espo. I also looked at Performance Products when trying to find the kit, but couldn't find it on their web site - might need to give them a call.
    Conny
    _____________________
    1973 911S Targa 2.4 MFI
    That kit will only work if your door isn't too far gone. There has to be enough material left to sandwich between the plates that come in the kit ... otherwise, see Espo.
    -Marco
    TLG Auto: Website
  1. 901 Transmission Mount Beam - Repair/Replacement Advice Wanted
    By StephenAcworth in forum Technical Info
    Last Post: 02-15-2013, 03:40 PM
  2. 73.5 door panel repair
    By crh in forum Technical Info
    Last Post: 11-20-2012, 03:32 AM
  3. Can I repair/replace fender bracket mount on battery box?
    By mobius911 in forum Technical Info
    Last Post: 04-14-2012, 08:48 PM
  4. 1968 door pocket elastic repair
    By 911scfanatic in forum Technical Info
    Last Post: 05-08-2009, 05:49 PM
  5. 68 Door panel repair ideas
    By mjmoran in forum Technical Info
    Last Post: 04-05-2005, 12:17 PM
