Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 1970 911 s pop on decel
    The car runs great, but after a 50 mile ride today, she popped real loud on two separate occasions. The car never does this, so is this a sign something is up, or does this just happen sometimes? Maybe gas related, or is it time to call Gus Phister?
    RGruppe member 445
    Do you have the speed switch (rpm transducer fuel shutoff on overrun) enabled?
    Ok, so far so good. I took the S out today for another 50 miles. No pops today! Thank God, MFI can be a bit tough sometimes.
    RGruppe member 445
    If the MFI is dialed in and the micro switch cut off is working then your throttle bodies might be starting to wear. How is your idle ?
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Funny that you ask that. The idle seems a touch lower than is normal. As a matter of fact when going into neutral after higher revs, I found the red battery light came on, but went off once I gave the car a bit of gas.
    Hmmm!
    Any thoughts?
    RGruppe member 445
    When was the point gap and ignition timing last checked?
    with worn throttle bodies idle will actually rise above the 900rpm norm
    99% of the time we think the pump needs to be rebuilt, it does not.
    Start the car and make sure you are not wearing anything that can catch in the fan, no rings, neckties, etc.
    Raise the rpm by moving the throttle crossbar, to about 2400 rpm. OK, now with the engine held there, actuate the throttle microswitch with your other hand.
    The RPM should instantly fall to below 1300 rpm, then rise to 1500, then fall to 1300, then rise etc. With a properly working overrun cutoff circuit that is the correct mode of operation.
    okay, it happend again. Time to get it in the shop. Thanks for all these ideas and things to check. I will make sure the mechanic looks at all of them.
    RGruppe member 445
    Did it pop in the intake or out the exhaust?
    -Marco
    TLG Auto: Website
  1. 911 s 1970
    By Motorsen in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-29-2020, 09:58 AM
  2. wtb: front seatbelt set for 1970 911 (dated 1969 or 1970)
    By Kaleid in forum For Sale: 911 Parts
    Last Post: 10-01-2011, 05:50 PM
  3. Replies: 4
    Last Post: 05-03-2011, 10:31 AM
  4. 1970 S on E-bay
    By Six Gun in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-21-2010, 04:11 AM
