Results 1 to 9 of 9
Thread: Tyres sizes on 7R's
    Tyres sizes on 7R's
    There is a thread in General Info but thought I would ask here also
    I have STD guards on a 72 and want to run the widest possible tyre on 7R rims that I can without fouling guard inner lips of bolts on spring plates
    What do I need to do re spacers and I prefer not to do longer stud bolts rather but the adaptors if I need to.
    What size will fit, with what spacers on the 7R's please
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Jan 2003
    UK
    I've used 15mm spacers (wheel adapters) & 215/60 Avon CR6ZZ tyres on 2 of my (lwb) cars with 7R rims in the past.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Quote Originally Posted by andyjboy View Post
    With no other mods I assume other than the spacer/adaptor
    Clyde Boyer
    Jan 2003
    UK
    Sorry Clyde, I should have added that I was running larger torsion bars (21/26mm), increased negative camber on the rear (2deg from memory) & rolled fender lips - both cars were lowered too ...
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Yep that all counts!!!
    Clyde Boyer
    Jan 2003
    UK
    Just remembered I also ran a similar suspension set-up with 15mm spacers & 225/50 tyres on 7R rims on my ex-Kurt Zimmerman RS-engined black '71E Targa
    Andy
    Early 911S Reg #753
    R Gruppe #105
    old softie67S
    Feb 2007
    Sanibel Fl
    I have run 225/50 with 15mm spacers on a swb. I would have to think they would fit a LWB unless oil cooler lines become a factor.
    Tom
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    I have 225/50 on my 70 S, but it requires a lot of neg camber. I have big bars too but it is pretty low. Harvey Weidman supplied the spacers.
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    May 2005
    Oroville, CA
    Clyde, 225/50s will fit. There are some 225/50s that measure wider up to 1 inch, but I have never found one that I couldn't fit.. I have put on wider 245s but it takes some careful planning ....and race suspension ...and sometimes fender alinging. The 225/50 set up is what we use on street suspension. You may have to rotate the cooler lines or dimple the inner fender behind the lines if there is a problem on the RR. Use 12-15 spacers or 15 Bolt to bolt.
    H
  1. FS: Deep 6 and 7R's with new tires
    By RSwannabe in forum For Sale: 911 Parts
    Last Post: 05-11-2011, 05:14 PM
  2. FS 15x7 Fuchs 7R's
    By Bobby Smith in forum For Sale: 911 Parts
    Last Post: 03-26-2010, 08:13 AM
  3. 7R's for sale
    By res6ll2a in forum For Sale: 911 Parts
    Last Post: 04-15-2009, 05:40 PM
  4. 7R's on the front wheels?
    By CamBiscuit in forum Technical Info
    Last Post: 08-11-2008, 12:50 PM
