Thread: '66 SWB car, what is the best brake upgrade?
    I'm looking for a brake upgrade for my '66 hot rod. Anyone have any suggestions? The car is only used for street use, but with the upgraded motor, factory brakes feel very insufficient!
    Granted my 67S has ventilated rotors, but with good brake fluid and porterfield pads no amount of hard driving out in the country will make them fade anymore.
    The pedal "feel" in a swb is softer than in later cars i've found, not sure why. If you haven't made them fade though, you don't have a problem.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Oct 2008
    Burford, ON, Canada
    This has been discussed before. The trick is to go to vented rotors front & rear. There is a Brembo caliper with 3" mounts very similar to the 911S aluminum caliper for the front. I think AlanUK has the rear calipers figured out.
    ah, ok perfect, thanks guys!
  1. Brake Upgrade
    By leadrsa729 in forum Technical Info
    Last Post: 04-06-2012, 09:21 AM
  2. turbo brake upgrade
    By gwilliams in forum Technical Info
    Last Post: 02-19-2012, 06:45 AM
  3. brake upgrade 71 rsr clone
    Last Post: 12-22-2011, 04:51 AM
  4. help with brake upgrade
    By BOYER73S in forum Technical Info
    Last Post: 03-08-2011, 05:28 PM
  5. Brake upgrade
    By Chuck Miller in forum Technical Info
    Last Post: 11-09-2002, 09:30 PM
