Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Qs re Installing rear sway ball pins
    Port Macquarie, Australia
    Hi Guys
    I will be installing a factory 15mm rear sway on my car. It's never had one before. I have the correct consoles to weld on and the ball pins to weld to the steel swing arms. I'm chasing some good photos of where/how the pins are installed.
    I've read Ed Mayo's write up of the install on a SWB, but the later steel arms are different...
    Any photos or advice would be great
    John Forcier
    EarlyS #1987
    Restoration Saga
    Hi John,
    We have done loads in the past both SWB and LWB, I will see what pics I can find.
    Alan
    Thanks Alan, very much appreciated!
    John Forcier
    EarlyS #1987
    Restoration Saga
    Still keen on pics peeps
    John Forcier
    EarlyS #1987
    Restoration Saga
    I figured Alan would have posted some already, I'll take a couple pictures tomorrow that might help you. I just did this very job a couple months ago, of course I didn't take any pictures, wouldn't ever get anything done if I did that! Everything is the same as a SWB except how you weld the pin to the arm. You won't be able to do it exactly like it was done when the arm was being fabricated.
    Hi Ed
    That's exactly my thoughts, so I was keen to see how others have tackled the install when adding the ball pickups after the arm has been fabricated.
    Thanks again
    John Forcier
    EarlyS #1987
    Restoration Saga
    Anyone got a photo of LWB steel trailing arms with the ball sway bar pickups?
    Cheers
    John Forcier
    EarlyS #1987
    Restoration Saga
    Sorry for the delay John, I finally remembered to take pictures today. I'm sure the ball pin was welded to both of the plates first, then the plates were welded to the arm. On a later install, since I wasn't about to cut off then reweld plates back to the arm, I found that I could install the ball pin far enough into both inner and outer plates so that the tip of the pin just reached the arm itself. I was able then to get the mig welder tip up in there far enough to get a short bead welding the tip of the ball pin to the arm. I don't have pictures of that, never thought any one would ask!! These are of a stock arm.
    Thanks very much Ed
    That certainly helps. I don't think mine have that second reinforcing plate behind... I have MIG and TIG, so hopefully I can squeeze one of them in there!
    Cheers
    John Forcier
    EarlyS #1987
    Restoration Saga
    That's correct John, if it didn't have a sway bar that second reinforcing plate isn't there, that's why you have to weld the tip of the pin to the arm itself.
  1. Replies: 1
    Last Post: 09-25-2013, 04:57 AM
  2. WTB: ball pins for rear swaybar, and bushings 15mm
    By xpensivewino in forum For Sale: 911 Parts
    Last Post: 02-05-2013, 08:05 AM
  3. WTB 914 R Shock bolts w/ball for sway bar mount
    By Bobby Smith in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 10-04-2011, 07:17 AM
  4. WTB RARB Consoles and Ball Pins
    By Fishcop in forum For Sale: 911 Parts
    Last Post: 02-10-2011, 01:22 AM
  5. Ball pin for rear sway bar need source.
    By MarkS in forum Technical Info
    Last Post: 09-11-2007, 07:16 PM
