Thread: Oil tank removal. 68 Sporto
    Member 1488 MrJTP2001's Avatar
    Nov 2008
    Denver area
    Angry Oil tank removal. 68 Sporto
    Car has been sitting for most of the last 20 years, on the gulf coast, so its time to check/clean the oil tank along with everything else.
    I've removed the rear bumpers.
    I've removed the three mounting nuts, 2 inside engine room, one in fender well.
    I've removed the oil filler neck and the rubber hose adapter.
    I've removed the oil filter and filter adapter.
    I've removed all hoses.
    I've removed the cover over the sending unit and disconnected the wiring.
    I've drained the oil.
    I've tried to move the fender brace (the PET calls it a strut) and stopped, I believe, just short of ripping it loose. I was pretty sure it was welded in place but had to make sure.
    I've even read the factory shop manual and it doesn't mention removal/replacing the tank.
    The tank moves around but won't come out.
    What am I missing?
    TIA
    Tony
    68 Sporto Project
    2016 Boxster
    Well, the fender brace, a J-shaped tube, has screw threads on one end of it. It goes through the rear longitudinal and attaches with a big nut. That's what the forward edge of the tank is attached to. It's attached by a clamp that consists of a folded piece of sheet metal with a clamp screw around the tube. These are uber-rare as they faded into oxide just after the car exited the factory before the test track.
    Nov 2008
    Denver area
    Of course, you just joggled my mind enough to realize how to move that J-tube.
    A thousand thanks!!
    Tony
    68 Sporto Project
    2016 Boxster
    A man never stands so tall as when bending to help a short wheelbase 911.
  1. FS- 1968 Sporto Oil Tank used but sollid
    By hwgunner in forum For Sale: 911 Parts
    Last Post: 03-29-2013, 11:36 AM
  2. Gas tank removal
    By Chris Pomares in forum Technical Info
    Last Post: 05-27-2012, 02:40 PM
  3. SWB oil tank removal
    Last Post: 11-16-2008, 03:27 PM
  4. 72 911 gas tank removal---help!?
    By flatsix in forum Technical Info
    Last Post: 08-21-2001, 01:55 PM
