Results 1 to 9 of 9
Thread: Fender oil cooler stone guards repro availability ?
    Feb 2005
    Montreal, Canada
    Hi,
    Since the original 69-71 S oil cooler and stone guard are rare and expensive and because I want 2 coolers, one on each side, I'm thinking of using late Carrera coolers but with a custom made stone guards that will replicate the original early guards.
    Does someone know a source of guard replica or someone who can do the small louvers ? All hot rod guys are doing louvers that are too far one from the others (and with round edges)
    I need someone who can do louvers on aluminium plate, so I can cut and fit the panel.
    Let me know !
    Thanks, Regards
    JD
    Sep 2006
    Eagle, Idaho
    Have you discussed this with Chuck Moreland at Elephant Racing ?
    I'd be surprised if he's not in a position to pull the necessary parts off his shelf and ship to you the next day.
    Apr 2011
    Germany
    I can offer you a full set with perfect fit in made in aluminium for 700 USD + shipping!
    Porsche 911 S 1971 Kremer race car
    Quote Originally Posted by 911r67 View Post
    Love to see some pics of those if JD doesn't want them as I am doing a twin cooler ST and need a pair also
    clyde@the-boyers.biz
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Apr 2011
    Germany
    Quote Originally Posted by boyer73s View Post
    love to see some pics of those if jd doesn't want them as i am doing a twin cooler st and need a pair also
    here is the pic!Name:  kühlerbleche.jpg
    Feb 2005
    Montreal, Canada
    John ; I talked to Chuck at Elephant Racing ; For the right side carrera stone guard, he used the stock one still available from Porsche. For the driver side he installed cooler upside down, since he run the oil lines in front of the car instead of in the trunk as the 911R. So he cut and modified a stock guard to fit over, but without opening for oil lines. He think of doing a kit to replicate the 911R setup, but he need a volonter and a donor car to develop the kit. So no help on this side for now, since I'm in Montreal, Canada !
    911r67 ; your guards look very good, but over my expectation in $...
    Any other source ?
    JD
    Senior Member aporschaguy's Avatar
    Feb 2005
    Great White North
    Seeing the quality of work that Marek does in alluminum (and everything else) don't you think he'd be the man to ask for such a job?
    You can contact him at the following link if you don't know who he is.
    http://www.early911sregistry.org/for...php?4198-Marek
    "He has all the virtues I dislike and none of the vices I admire."
    1971 911e
    1978 911sc Targa (Sold)
    1973 911 RSR (Clone)
    A guy can take the factory guard and rivet on an extension to make it fill out the ST fender swell. For the driver side, simply take the passenger side unit and reverse the bends for the cooler openings, cut the flange and reweld. A good aluminum welder can do this very easily. Then add tabs to line up with the factory Behr cooler brackets and you're there. These factory guards fit perfectly over the surface of the Behr cooler to protect it from flying rocks, so it is a fairly easy project. You can find these guards for $50-60 on eBay, and the welding work should cost no more than $150 for both.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Feb 2005
    Montreal, Canada
    Thanks Guys, but I would like the original look ; Does someone have a source for the original - passenger side ? (as my first photo)
    JD
  1. FS: Auto Foreign New for 356, Stone Guards for headlights
    By Soterik in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 07-24-2013, 09:53 AM
  2. Replies: 8
    Last Post: 09-18-2012, 08:28 PM
  3. Replies: 1
    Last Post: 09-20-2011, 08:38 PM
  4. Replies: 0
    Last Post: 06-14-2011, 01:43 PM
  5. Availability of SWB Guards (Front and Rear)
    By reedminor in forum For Sale: 911 Parts
    Last Post: 09-20-2010, 11:27 AM
