Thread: Help installing Bendix fuel pump in 67 to look period correct
    I'm installing a Bendix (Facet) fuel pump in a 67 911 that is quite original. The 8mm fuel line across the rear member is fed by a fuel line from the pump and the pump is supplied from the fuel line from the tank. I would like some photos of these two lines and the fittings used at the fuel pump to help create the best appearing connections. Pump has 1/8" NPTF fittings and currently uses 90 degree, brass hose barbs.
    Thanks!
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    here is a pic of the bendix with proper banjos
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    Flunder; Perfect, thank you!
    Paul Abbott
    Early S Member #18
    530.520.5816
    Paul, here is my solution for what it's worth. Facet pump, Bendix decal, tap pump for 10 X 1.00 banjo, use standard metric banjo and bolt. I crimped the lines to the fittings, but I think that was a mistake, they should just be pushed onto an uncrimped ferrule. Not 100% correct, but at a glance looks OK.
  1. Fs swb bendix fuel pump
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 11-18-2011, 08:37 PM
  2. WTB: Bendix fuel pump
    By JPlonghood in forum For Sale: 911 Parts
    Last Post: 12-06-2010, 04:11 PM
  3. Bendix fuel pump
    By res0ca5d in forum For Sale: 911 Parts
    Last Post: 11-15-2008, 09:20 AM
  4. Bendix Fuel Pump
    By Neil '67 911S in forum Technical Info
    Last Post: 03-26-2007, 02:30 PM
