Thread: How much a 2.2 engine and a 901 transmission weight?
    Dear all,
    I need to send a 2.2s engine and a 901 transmission from Thailand to be restored in Phoenix. The shipping company asked for the weight of both.
    They need it to calculate the cost for sea shipping.
    Any idea?
    Many thanks
    Burint
    http://thaiporsche.shutterfly.com/action/
    The Unbreakable RS/RSR door pull http://thaiporsche.shutterfly.com/776
    86, 930
    70, 3.2
    67, 911
    Apr 2010
    Kalimantan <SeaTac<Philly
    hi, engine is about 400lbs, gearbox 80lbs. or in french kilogrammes thats 400/2.2 and 80/2.2.
    i made the weight more that actual, pack on wooden pallet. minimum weight could be less, without MFI.
    which shop you sending it to?
    Just looking at this infomation in the porsche workshop manual last night. From memory it said that a 2.2E engine was 185 kg dry and a gearbox was 50 kg dry.
    HTH.
    Kind Regards
    John #1022
    1970 911E 2.2
    Just checked the manual and the wieghts are the same for T E and S models. The extract from the manual states
    Weight of engine, ready to install, without oil.......approx 184 Kg (406 lb)
    Weight of transmittion, ready to insatll, with oil......approx 50 Kg (110 lb)
    Kind Regards
    John #1022
    1970 911E 2.2
    Reza,
    I will send it to Chris Carroll at Turbo Kraft.
    Chris will work on the engine and the transmission.
    He's probably will send the pump to Gus.
    Many thanks for all your information.
    86, 930
    70, 3.2
    67, 911
  1. WTB: Looking for engine & transmission
    By rliberty in forum For Sale: 911 Parts
    Last Post: 10-06-2013, 07:59 AM
  2. 915 transmission weight
    By WP935 in forum Technical Info
    Last Post: 08-24-2013, 03:14 AM
  3. 1973 911 engine weight?
    By mac73s in forum Technical Info
    Last Post: 06-14-2013, 05:03 AM
  4. 1965 911 engine weight?
    By demo in forum General Info
    Last Post: 08-08-2007, 09:43 AM
  5. engine weight
    By timothfarrar in forum Technical Info
    Last Post: 05-13-2003, 06:15 PM
