Thread: 2.2L Sticker Install - Rear window removal?
    I'm planning to replace my faded 2.2L sticker on the rear window with a new one I recently bought. Has anyone done this successfully without having to remove the rear window? There doesn't appear to be a whole lot of room to manoeuvre back there. Suggestions appreciated.
    Use a long handled razor blade scraper, then clean with alcohol or VERY carefully with some acetone on a swab. Cover the area underneath well if you use acetone as this will spot your vinyl.
    use some water with a little dishwashing soap to apply the new sticker
    Thanks for the replies. Jeroen914, when you say use the water with dishwashing soap is that for use before applying the sticker or afterwards to smooth away any unwanted air bubbles?
    Before / it allows you oppty to slide around and position
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
  1. Soft window install
    By speedo in forum Technical Info
    Last Post: 05-29-2013, 05:27 PM
  2. Removal of DOT sticker
    By Original Poster in forum Technical Info
    Last Post: 02-12-2013, 03:05 AM
  3. 72 Targa rear window glass install in Atlanta
    By Joe Minor in forum General Info
    Last Post: 11-28-2008, 05:03 PM
  4. help! removal of rear window Targa
    By EARLY911ZOO in forum Technical Info
    Last Post: 07-10-2008, 06:20 AM
  5. Targa Rear Window Removal
    By eaglenav1 in forum Technical Info
    Last Post: 05-30-2001, 12:24 PM
