Thread: Race Gas vs Pump Gas..mix?
    I recently bought a 1975 911 with an '87 3.2 motor. The previous owner used the car only for track use.
    The motor is a 3.2, with PMO carbs. The previous owner was running 110 octane race gas. Aside from being a carb car, and not fuel injected, the motor is a stock 3.2, and the previous owner did not make any adjustments to the timing for the race gas. He just said he thought it ran better with the race gas.
    At $12/gallon, I'd prefer to run premium pump gas..plus it's easier to get..
    Is there any reason I can't run pump gas? Can I mix unleaded into a tank of leaded race gas?
    "Speed never killed anyone. Suddenly becoming stationary...that's what get's you."
    1973 Austin Mini
    1975 911S 3.2 "the blue goose"
    1973 911E sunroof 3.2
    Yeah, run 91 and you will be fine with stock ecu. Only need higher octane if you are running high advance on your timing and/or extreme heat conditions (and of course if you are boosting with a turbo or SC or raising the compression somehow higher than stock)...but seriously you need a race map to benefit from the 110 and all the map would do for a carb motor would be advance the timing.
    thanks for the feedback... Is it ok to mix unleaded into a tank of leaded gas?
    1973 Austin Mini
    yes you can mix.
    Nick D member #403 nickd's Avatar
    Jul 2005
    Landenberg, PA
    I mix leaded race fuel and normal pump gas - mfi pump enjoys a little lead ..
    Nick D - Run Flat
    1973 RHD 911 Carrera RS #0358 - Fun Car
    2016 Cayenne Diesel - Tow Car
    2017 Macan S - Better Half's Car
    1955 356 Speedster SOLD
    1976 911 2.7 SOLD
    2006 Cayman S SOLD
    2006 Cayenne S SOLD
    2008 Carrera S F77 SOLD
    2011 Cayenne S TOTALLED (T-Boned but kept us safe)
    2015 Macan S SOLD
    2015 GT3 - Track Car
    2016 Cayenne SOLD
    2016 Cayenne GTS TOTALLED (Bloody big deer)
    Still looking for 1st Edition Carrera RS book #358.
    Life is way too short to drive boring cars.
  1. SCRS kugelfischer race pump.
    By stretch in forum Other Porsche Passions
    Last Post: 11-21-2017, 02:58 PM
  2. SCRS kugelfischer race pump.
    By stretch in forum Technical Info
    Last Post: 10-24-2013, 05:12 PM
  3. 1967 911 Vintage Period Race Car, 40 Year Race Career
    By Rennman in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-06-2012, 07:13 AM
  4. FS: 930 oil pump, as new, race modified
    By kenikh in forum For Sale: 911 Parts
    Last Post: 10-04-2010, 06:05 PM
