Results 1 to 8 of 8
Thread: How to clean hood latch
    Senior Member BlackC4's Avatar
    Apr 2011
    Atlanta, GA
    The hood latch mechanism on the bonnet and the engine lid are old and funky looking. What is the best way to clean these to restore them back to a presentable fashion?
    '73.5 911T Coupe Sportomatic Light Yellow (117)
    '73 911T Targa Sportomatic Light Yellow (117) - Sold
    '99 996 Carrera 4 Black - Sold
    The Other Stuff:
    '63 Corvette Split Window
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    Do you intend to remove them (and therefore lose your adjustment) or clean them in place?
    I use Wurth citrus degreaser and a detail or tooth brush. It works great in the door jambs and strikers. Use alchohol and water in a spray bottle to flush it all away after the crud is broken down.
    Don
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    If you pull it $30 to have it re plated clear or blue zinc unless you can get cadmium in your area.
    Apr 2011
    Atlanta, GA
    They are all out of the car. I really don't want to spend a couple hours scrubbing each latch with a toothbrush. I was hoping there was some sort of soaking solution or spray on solution that you can spray and wipe with minimal scrubbing except for the seams.
    The Other Stuff:
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    Since you have the latch out I'd suggest finding a local plater that does clear (ie.silver) zinc plating. No amount of scrubbing will get that newly plated look. All your cleaning will do is get the grease and gunk off the latch, not a bad thing mind you, but at least around here the cost of replating makes spending any time hand cleaning kind of fruitless. Be sure to first remove that spring cup before plating anything.
    I don't think you will have problems with the upper cup for the spring, but the lower one, the pointed one that contacts the striker, will turn black if you try to have it plated conventionally.
    Nov 2004
    Gold Coast.
    The cup is alloy and will get eaten up in the plating process
  1. FS: Hood Latch Receiver, Deck Lid Latch and Receiver Fresh!
    By 76911S in forum For Sale: 911 Parts
    Last Post: 09-01-2013, 01:32 PM
  2. FS: 69-73 hood latch
    Last Post: 05-19-2012, 06:10 AM
  3. WTB: Hood latch and Reciever for a Long Hood.
    By C.Plavan in forum For Sale: 911 Parts
    Last Post: 04-04-2012, 03:56 PM
  4. Replies: 10
    Last Post: 03-05-2012, 12:44 PM
  5. 911 hood latch
    By Needle in forum General Info
    Last Post: 03-26-2004, 08:35 PM
