Results 1 to 7 of 7
Thread: 85 liter tank
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    85 liter tank
    Are there any complications when installing a 85 liter tank in a lwb with mechanical mfi or carbs.?....Cliff
    You'll need to come up with the attachment pieces, it'll have both inlet and outlet fittings for the MFI, (and I think a third for a Webasto), the vent tube is the same, but i believe you'll need a longer hose to connect the filler neck. Oh,,and don't forget the space saver spare and pump.
    Mar 2006
    8903one
    Seems not to be too much trouble to me. Are these parts readily available. Fitment to the body was my biggest concern with clearances on the bottom.Thank you. ....Cliff
    The top clamps are available but the cup bracket at the front is NLA and will need to be made. You will also have to add the top clamp mounts to the bulk head, all pretty straight forward. If you need a longer hose for the filler I have a few in stock. I also can get some pics if it helps as we have 2 cars in the workshop with 85 ltr plastic tanks at the moment. One being a 2.7RS.
    HTH
    Alan
    Hi Alan, I need the (3) top clamps for a 85 plastic RS tank. Can you supply? Two (2) are straight in roughly the 10 and 2 O'clock positions, the third one is angled at the 6 O'clock position looking down at the top or the tank installed. Thanks, John
    I also need a longer sender unit for the 85 tank, can you supply that too?
    Mar 2006
    8903one
    I was referring to a steel tank.....sorry for not spelling that out.....Cliff
  1. FS 100 liter tank with sender
    By fishman7 in forum For Sale: 911 Parts
    Last Post: 12-08-2010, 10:52 AM
  2. Plastic tank to trade for 100 liter steel tank
    Last Post: 04-12-2010, 09:13 AM
  3. WTB - 100 liter gas tank SENDER
    By sezme in forum For Sale: 911 Parts
    Last Post: 02-27-2009, 07:12 AM
  4. 100 liter gas tank
    Last Post: 02-15-2009, 04:59 PM
  5. early 911 100 liter tank: still available?
    By turfclubroad in forum Technical Info
    Last Post: 10-12-2004, 12:05 AM
