Thread: Battery / charging system question
    Hi guys,
    I'm looking at a lightweight lithium-based battery for my 1969 911E race car.
    The battery I am considering appears to have sufficient CCA. However, the seller has mentioned that, despite it having an inbuilt protection circuit module, it should not be overcharged by more than 24AH input.
    Does anyone know the battery charging input of an early 911?
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
    Jul 2008
    South Florida
    IIRC the standard alternator is 14V/35A, later 14V/55A?
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Thanks Russ
    Cheers, Ryan
    Jul 2008
    South Florida
    Baker or Braille make LW batteries, reasonably priced. I've used both, depends on what you want to spend.
    The Braille CF's are around $250, they also make Lithium cells if you wanna spend 10X more!
    Russ
    ESR # 1537
    '70 914/6 GT
  1. Question on Battery box
    By nammon in forum General Info
    Last Post: 05-05-2012, 02:50 AM
  2. Quick Battery Question
    By jaudette3 in forum Technical Info
    Last Post: 12-29-2008, 01:27 AM
  3. battery charging assistance
    By jdevil325 in forum Technical Info
    Last Post: 06-21-2008, 11:12 AM
  4. Fuel system question
    Last Post: 06-01-2007, 02:24 PM
  5. battery(s) charging
    By joelrkaplan in forum Technical Info
    Last Post: 12-20-2003, 06:20 AM
