Results 1 to 2 of 2
Thread: Two-versions of Weber 40 IDA 3C Carburetor Delivery Valves?
    Each Weber 40 IDA 3C carburetor has three Delivery Valves: Weber part number 64290.005, item 71 in the Weber exploded view drawing. It’s the brass check valve that holds the Pump Jet item 71 (squirter) in place.
    I recently removed both carbs for rebuild, but decided to do them one at a time. I disassembled the first carb and subsequently soaked and cleaned everything. I was checking parts for assembly when I noticed that one of the Delivery Valves didn’t have the little check ball inside it. I discussed the finding with a few friends, and consulted with some experts. It was easy to conclude that the part must have been defective, so I ordered a few new ones from the Oil Analysis Company. The Oil Analysis Company is a retailer/distributor of PMO Weber stuff. BTW, I have had great success when dealing with both of these companies.
    Anyway, I then decided to disassemble the second carb prior to assembly of the first one and guess what? The center Delivery Valve didn’t have the check ball either. Maybe everyone already knows this, but I have looked and can’t find it documented anywhere.
    Thoughts? Comments?
    Note, I have also started this thread on the Pelican Technical Forum but thought it might be more appropriate on this forum.
    Indiana,
    1965 911: 300594, 300839
    1965 912: 350407,
    1968 911L SWT Sportomatic,
    1970 911T Irish Green, Restored,
    1974 911 Carrera, 1975 911 Carrera,
    1970 914 1.7 Signal Orange, 1973 914 2.0 Zambezi Green, 1974 914 2.0 Ravena Green--this one is for sale
    Used to haul the kids to the pool in 356/1500RS Carrera Speedster 80820. Wife would leave it in the shopping center parking lot -- now in the Porsche Factory Museum.
    The end requirement here is that all three nozzles spray fuel when the pump diaphragm is compressed. My guess is that this was someone's fix for something, who knows. You'll need to measure the pump discharge quantity and adjust for the lower end of the tolerance, memory says .4cc's per two squirts,,,but check me on this.
  1. FS: Weber carburetor master catalog technical introduction 1967
    By 88cs in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 07-06-2013, 04:54 PM
  2. Weber carburetor dating and history of changes
    By haycait911 in forum Technical Info
    Last Post: 03-05-2011, 12:59 AM
  3. LWB front turnsignals - Euro & US versions
    By andyjboy in forum For Sale: 911 Parts
    Last Post: 09-15-2007, 10:42 AM
  4. Different versions of 4,5" Fuchs
    By tobiasax in forum Technical Info
    Last Post: 01-17-2003, 04:12 PM
