DSCN1921.jpgDSCN1922.jpgFor sale are NLA (no longer available) early 911 camshaft feed hose with ferrell. New part. This hose fits all 911 engines from 68 to 89. It is designed for use with the 1984 and later tensioners and is longer than the hose currently availble. It does not require the oil pressure sender or a spacer block to be installed due the the currently available hose being too short. This makes for a much cleaner installation on early cars without the rear mounted pressure sender. Replaces the current part # 930 107 348 11 that requires the spacer block on 68 to 73 engines. The original part number for this hose is 930 107 348 01. It is 10 1/2 inch long as shown in the photo. I found a quanity of these in my parts stash so multiple quanities are available. $25.00 each plus shipping.
