Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: FS: Center Lube Cam Lines
    Any interest in center lube cam lines? I have sent a set of original center lube cam lines to Cohline in Germany to duplicate the metal tube hard line sections. They will make the hard lines exactly as original with the crimp collar stop and flare. I will assemble the lines with correct single blue tracer hose as originally used back in the day. There is also have the option of the Cohline orange tracer hose if you prefer. The plating on the crimp collars and hard lines will be gold cad as original. Pricing is $250 per set. I need to sell 12 sets to make everything work out. Correct for an early Solex engine and some of the early center lube race engines. 911R / 906
    Here are a few shots of the original lines sent to Cohline. Thank you to Mike Curnow for supplying the sample lines.
    Best regards,
    Brad
    949 266 4205
    Brad Davis
    RGruppe #691
    Early 911S #1547
    May 2005
    Southern California
    Sign me up for 3 sets. Thanks Brad! You can email me at ajserrano at msn . com
    I would like 2 sets please.
    With kind regards,
    Chris Mulder
    I would like one set please.
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    Sep 2006
    La Quinta
    I'll take one set with blue tracer. Is there a way to get them in silver rather than gold?
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Thanks Guys.
    We are getting close.
    John, Cohline will probably send the fittings in silver. I plan to then run a gold cad batch for all the fittings. I will be sure to set aside a few silver sets.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Brad,
    You could put me in for a set. Definitely silver cad with the blue tracer. I think John and I are going fir the early 65' look. I started this project myself and would gladly let you finish it. I have collets, flairs, nuts and slip flairs for several sets. I've also made up several of the less complicated tube sections. All of it is plated silver cad. Im in Los Angeles and would gladly ship the parts down to you. Ill try to give a call in the next few days.
    Apr 2011
    Germany
    Count me in for two sets please!
    Porsche 911 S 1971 Kremer race car
    Hi Brad,
    I would like to buy one set please. Yellow with a blue tracer.
    Matt
    Brad, as a note, some of the late 'R's / St's / RSR's do not use the nut and ferel (cutting ring) system of oil line for cam central oiling. The left side uses a hollow bolt and banjo under the distributor and a brazed 12mm Fuel like fitting at the cam cover end. The right side uses the brazed type fittings at both ends. The early 911's with cam central oiling and the 906's definitely use your nut and ferel system. I don' Know about the 914-6 GT. If the chain covers are are the RSR type (late R to 935) than the 12mm brazed lines were used. Gordon
  1. FS: center lube cam boxes
    By geneulm in forum For Sale: 911 Parts
    Last Post: 05-24-2013, 05:55 PM
  2. 65` center lube engine
    By Cliff in forum General Info
    Last Post: 05-08-2012, 06:53 AM
  3. Center lube fitting
    By 912-2.8 in forum Technical Info
    Last Post: 04-03-2011, 06:28 PM
  4. Center lube Cams
    By ryanmadson in forum For Sale: 911 Parts
    Last Post: 01-29-2009, 09:02 AM
  5. FS: New Center Lube cam seals
    By PJenkins in forum For Sale: 911 Parts
    Last Post: 06-26-2008, 06:18 AM
