Thread: FS: Hella 65-67 USA Headlight Parts Lot
    Bought multiple sets to assemble one set for my recent Cibie Biode project. These are the left overs. They are the parts required to assemble 65-67 USA style headlights with your choice of lamps.
    THIS APPLIES TO ALL: Please note in re: to condition, everything listed requires media blasting and refinishing. The tab portion on most of the rings have been lightly tapped to prevent the lights from bouncing around upon final assembly. It doesn't look pretty but works and will not be seen after assembly and install. Rings may or may not retain their original bushings. These should be replaced. I can include a firm rubber vacuum line (enough for both rings) to be cut to required sizes for additional $5. Items will be packaged in a Medium Flat Rate Priority Box which is $11.
    A: Two rings. $20 plus $11 Medium Flat Rate Priority Box shipping. Add $5 for if you want vacuum line for bushings.
    B: Two rings. $20 plus $11 Medium Flat Rate Priority Box shipping. Add $5 for if you want vacuum line for bushings.
    C: This is not a set. This is for one ring. Did not make a set because the tab is different and did not have a matching ring. See pic for detail of rivet style attachment. $10 plus $11 Medium Flat Rate Priority Box shipping. Add $5 for if you want vacuum line for bushings.
    D: One very crusty bucket with city light opening. One alum retaining ring with one broken tab. FREE...well almost free. If you want to buy me a venti mocha to package, stand in line at the post office and burn my lunch hour then $4.35 plus $11 Medium Flat Rate Priority Box shipping. SOLD
    E: One bucket marked Hella 1V8 001 509 00 SB 19 M 35. It has the circle drain hole instead of the triangle drain hole. $10 plus $11 Medium Flat Rate Priority Box shipping. This of course can be combined with ring purchase for no extra shipping. SOLD
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Last pic of E.
    _B
    www.werkcrew.com
    Senior Member mrg3.6's Avatar
    Nov 2007
    United Kingdom
    PM sent
    Martin
    Nov 2007
    United Kingdom
    Bob has kindly advised me that I don't need these conversion rings for my existing setup so here's a bump.
    Martin
    Bump with price reductions to clean up garage. Half price on parts (except vacuum line/bushings) and can get the cost of shipping down to $8 via First Class.
    _B
    www.werkcrew.com
  1. FS: NOS hella 911 H1 headlight
    By moito in forum For Sale: 911 Parts
    Last Post: 07-09-2013, 11:55 PM
  2. NOS Hella Headlight Bucket
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 11-26-2012, 08:16 AM
  3. HELLA headlight lenses 65-67 19 20 21
    Last Post: 05-08-2011, 06:56 AM
  4. Hella headlight options
    By Cal in forum Technical Info
    Last Post: 03-16-2010, 09:46 AM
  5. FS- Hella USA Headlight Adjusters
    By 72tii in forum For Sale: 911 Parts
    Last Post: 02-07-2010, 12:56 PM
