Two vintage Rallye, map lights, Each $125,00. The lense on the rectangular light is slightely distorted. Both are 18 inches long.3% more with Pay Pal. These are at least 20 + years old.
The bottom light has been sold.
Mike
mike, can you do a favor for me? can you take a pic of the bottom of the second light (the butlers)? I bought one recently and it does not have a ground wire. the base does act like a ground and it works as long as its attached to a ground.. but i need to put a ground wire on it. if you could take a pic to show how the ground wire is attached and where, that would be a huge help and i would be for ever grateful.
btw, these are fantastic lights and as raj said in a previous post, its hard to find them with the clip. best of luck on the sale!
Harry Hoffman
356 Registry Member #36691
Mike,
I would like the second light if it has the clip. Thanks.
Don
The ground wire is attached to a thin brass washer with a tab on it to solder the wire to. It then is put over the switch and when the switch is mounted in the base it is squeezed between the white switch and the housing and the housing is grounded. The switch breakes the hot red wire
Mike
Mike
You have it. It has a clip, and I tested it and it actually works. Do you want to send a check or pay pal? Shipping in the U.S. is probably $6.00
Mike
Mike
I will paypal you mike. Please e mail me with your Paypal acct. DAhearn67@gmail.com Thanks.
Don
Second in line just in case Don gets hit by a bus tonight =) Shame on me for not buying this at Stoddard.
1974 911"S" - Silver
10 sec 67 VW
Early "S" Registry #439
thanks so much for the pic!! huge help!
Harry Hoffman
Don
I have not heard from you, or any Pay Pal activity. Did you get my E-Mail with my Pay Pal address?
Mike
Panzer
Rennman has not completed the deal. If you still want it its yours
mike
Mike
