I'm having a problem with my driver side window, I understand the problem, not so much the solution ;-) I bought the car with a non-working window (in a downpour), and indeed I fished the glass out of the door today, it's intact, but it doesn't want to stay in its bottom support channel.
Greg's incorrect nomenclature here:
A: Window winder with its 2 plastic thingamabobs.
B: Channel that receives the glass, sliding on the aforementioned thingamabobs (see artful bidirectional arrow on picture)
C: The glass, with a rubber bottom.
Here is the behavior - I'm making assumptions here that may be wrong:
I can pop the glass into The bottom channel B, and sort of guess on the alignment of A into B (B slides horizontally), and the window will wind UP OK - so I can stay dry (and hot). When I wind it down, the glass doesn't move and B pops out of the glass immediately, within I'd say 1" of travel, the A+B parts go down on their own….
Is it just a matter of glueing/attaching the glass bottom "better" into that B channel ? I checked the vertical guides for the window and I can slide the glass up and down by hand without "much" resistance. It's not exactly a guillotine, but it goes w/o much effort. Hard to quantify but it did not seem to be an issue. If the glass was kinda glued into B I think it'd go down. Ditto on the window regulator, it goes up and down very smoothly… So why is my glass separating from the bottom support channel ? I have a theory (everyone hide!!), I think it's got to do with the positioning of the glass into the B groove.
The sliding channel that receives the glass (B) appears to be sitting off axis vs the vertical window channels. In the picture below, the effect is *exaggerated* by the fact that B also slid too far back and now rubs on the vertical guide, definitely making it off center… I can recenter B. Problem is, what is center ?? Methink if B stayed "centered" between the 2 vertical grooves, it would stay aligned and support the glass all the way down.
So basically I am unsure of the correct initial positioning of A vs B vs C.
B slides on A, and it must do so to keep pushing the window up slanted vertical guides… But where is the correct start position ? Same with the glass, really, if B is positioned funny I imagine it'll make the glass pop off from the B channel…or it'll force the B part to touch the vertical guides… Is the glass glued/otherwise affixed to B normally?
I hope this mumbo jumbo makes sense…
Also, I found this in the bottom of the door, but the PET showed no similar part in the arrangement….
Any help would be gladly appreciated ;-) I'll go dismantle my 912 to compare and swap parts, if I have to !
