or
How a Pair of Kitchen Gloves, a Swiss Army Knife, and Bicycle Degreaser Fixed My Misfire
Hi everyone,
Long-time reader, first-time thread starter -- I thought I would document the process to hunt down and cure a misfire that happened over the weekend in my 2.0 66 normale with distributorless ignition by Electromotive. This is my first 911 and first carbureted car.
After accidentally filling up with 10% ethanol (as noticed by the Mrs.), I began to feel a misfire and stumbling at around 1900 rpm. This was noticed most when starting from a dead stop. Over the next 4 hours and 75 miles or so between DC and Annapolis, it started to get worse and was significantly apparent by the end of the day.
After about two hours of reading here and on Pelican, and recalling hours of puttering around downtown DC, I thought for sure I had fouled a plug. After spending $2.75 on a replacement NGK at the FLAPS, I donned a pair of rubber gloves and went about unplugging the spark plug wires at idle to find the bad cylinder. Why use rubber gloves? Try it without and ask me again. Turns out unplugging #1 didn't change what idle I had, but unplugging the rest did. Pulling the plug and noticing the flawless condition with a dusting of greyish-brown, I swapped it with cylinder #2. No change. After checking the wires, I surmised it was not an electrical problem and I would have to get all up in the Weber.
Luckily, the first recommended step is to look at the idle jet on #1. Not having a reasonably short flathead, I used my swiss army knife to pull out the jet and LO AND BEHOLD...a tiny piece of black something was blocking the top hole. Again using the swiss army knife toothpick, i flicked it out, shot some Finish Line Instant Degreaser (awesome stuff) into it to clear it out and re-installed to a perfect idle. I wish I knew this when I was on the road. I literally could have fixed this misfire on the dime, with a dime.
So, my question is: How did that black piece get there? It looked way too big to get through the fuel filter (about 1mm long). Could it somehow have gotten dislodged from my K&N? But that wouldn't explain how it got to the idle jet.
