Results 1 to 8 of 8
Thread: torque setting please
    Sep 2008
    Auckland , New Zealand
    engine oil sump plug and oil tank plug , what is the recommended torque settings , reason i ask i have done an oil change and for some reason the plug into the oil tank is weeping? the seal ring was replaced and the surfaces clean so i am a bit stumped
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Apr 2003
    Portland, OR
    Hi John:
    I never torque mine so I do not know that answer, I just tighten until snug and give it a bit of an extra turn until I feel the crush washer give.
    But, today, as I was adjusting my valves and changing my oil I suddenly thought of your question. One possible cause of a leak from these points is either a lack of the sealing (crush) washer or you have two where only one is needed.
    Good luck in figuring out the problem.
    Harry
    Member #789
    2009 MB C300
    Sep 2008
    cheers for the reply , i tighten it again today with socket and large socket bar , i just don't want to apply more pressure as the result will not be good . lets see what is on the floor tomorrow morning.
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Apr 2003
    Portland, OR
    John:
    You should not need to tighten it too much or you will create a greater problem.
    Harry
    Member #789
    2009 MB C300
    Jan 2003
    UK
    Recommended torque setting is:
    engine drain plug in sump & oil tank - 31 ft-lbs (42Nm)
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Sep 2008
    Thanks andy, i have torqued to this (and it is more than i would have thought ) lets see tomorrow if there is further drips
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    Quote Originally Posted by advtracing View Post
    Not to quible or try to split hairs with Andyjboy but I asked this same question of my guru and was told 28 ft-lbs was more than adequate. I agree - even that feels like it's tighter than necessary, but I've never had leaks at that setting.
    - MR
    Sep 2008
    well still at a loss , went out and checked , still weeping
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  1. Setting up Konis
    By Fishcop in forum Technical Info
    Last Post: 07-17-2015, 12:01 PM
  2. gap/dwell setting question
    By robmog in forum Technical Info
    Last Post: 09-29-2012, 06:11 AM
  3. Setting up MFI Pump on a racing car
    By ST Man in forum General Info
    Last Post: 11-30-2010, 08:33 AM
  4. Advice for setting timing...
    By berettafan in forum Technical Info
    Last Post: 05-15-2008, 12:12 PM
  5. Help Setting The Value Of 1972 T Sportomatic
    By 69S-S/R in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-10-2007, 10:02 AM
