Thread: H1 Adjustment/Aiming Help
    Aug 2006
    Chicago area
    I was readjusting my low beams higher on the H1's and that adjustment re-aimed my high beams higher. So... I readjusted those lower and darn if that didn't bring my low beams back down out of adjustment. Rather than fight this back and forth, can someone tell me if there is a way around this? Maybe a pivot point that should be lubricated?
    I know, seems a simple adjustment and kind of a dumb question, but I have to ask...
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Scott, not to be insulting here, but are you sure you have H-1's? H-1's have four adjusting screws, two for low beam and two for high beam. H-4's only have two. H-1's have letters and directional arrows cast in the lenses, A is for low beam, F then being for high beam.
    Aug 2006
    Chicago area
    No worries Ed. It is a bit of a dumb question I know. Yes they are H1s that is why I am am confused. I will mess with them again some more today.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
  1. Headlight aiming
    By tomh in forum Technical Info
    Last Post: 09-18-2012, 12:41 PM
  2. Shifter adjustment
    By Jay Laifman in forum Technical Info
    Last Post: 11-13-2011, 06:57 PM
  3. Aiming '66 non-sugar scoop headlights
    By 66DC in forum Technical Info
    Last Post: 11-06-2011, 07:32 AM
  4. 911 clutch adjustment
    By joetiii in forum Technical Info
    Last Post: 10-02-2008, 09:43 AM
  5. WTB: MFI Adjustment Screw NLA
    By jcarpio in forum For Sale: 911 Parts
    Last Post: 01-02-2008, 11:34 AM
