Thread: Sway bar question
    Question Sway bar question
    So my 69E had its hydropneumatic suspension labotomy quite a few years back and an H&H 3/4 inch (19mm) through body front sway bar was added at that time.
    I am looking to replace the mount bushing and all I've found is S model 18mm bushings. I tried installing them but they don't fit. It has been suggested I deep freeze the bushings and have them bored out to 19mm. I have no clue how/where to do this. the other option is to get an 18mm front bar. Though I am sure there will be other issues with drop link attachement etc.
    Suggestions?
    Joe
    '69 E Targa "Roxie"
    Early S #937
    Hi Joe,
    We use a aftermarket bush from "super pro" and have machined them to suit. Finding an 18 mm bar is not easy, they were used on early turbos. We made them in the end. If you get really stuck I could machine some up for you but I am in the UK.
    HTH
    Alan
    Alan,
    What type of shop would I search for that would do this machining?
    Joe
    Joe
    '69 E Targa "Roxie"
    Early S #937
    Hi Joe,
    I am not sure which type of shop, you just need someone that has the tools and is willing to help.
    Alan
  1. Sway Bar Mounting Question
    Last Post: 12-10-2012, 11:31 PM
  2. Quick Front Sway Bar Bushing Question
    By Haasman in forum Technical Info
    Last Post: 10-27-2012, 06:30 PM
  3. Front sway bar question for a 68
    By Rolls 912 in forum Technical Info
    Last Post: 01-23-2012, 03:14 AM
  4. sway bar question
    By hoffman912 in forum Technical Info
    Last Post: 12-19-2011, 05:36 AM
  5. Rear Sway Bar Drop Link Question -
    By zcat3 in forum Technical Info
    Last Post: 09-28-2004, 11:00 AM
