Results 1 to 10 of 14
Thread: 1973 carrera rs plastic gas tank
    Each time I open the front trunk I get a wiff of what seems to be a gas. I brought the car to my mechanic and he removed the bottom pan and no gas residue whatsoever. He also took the gas sender out, put a new gasket on and re-sealed everything, as well as putting in a new vent hose which was kinked. After all this, I still have the gas odor.
    Is this normal to a plastic gas tank as I have never had one in a Porsche before? Any ideas are very appreciated.
    Thank you,
    RGruppe member 445
    Hi John,
    It sounds like you might have a small crack in the tank.
    My old lightweight RS had a small crack under the hold-down clamp that leaked when the tank was fiilled. I would remove the hold-down clamps and carefully inspect everything.
    I fixed mine with some JB Weld that matched the plastic tank very nicely.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Aug 2007
    Phila Pa. area
    What bottom pan?
    Mike
    Nick D member #403 nickd's Avatar
    Jul 2005
    Landenberg, PA
    I'd guess John is talking about the sheet metal that cover the front suspension cross member , steering column / gas tank ports...... Protective plate 911 341 025 01
    Nick D - Run Flat
    1973 RHD 911 Carrera RS #0358 - Fun Car
    2016 Cayenne Diesel - Tow Car
    2017 Macan S - Better Half's Car
    1955 356 Speedster SOLD
    1976 911 2.7 SOLD
    2006 Cayman S SOLD
    2006 Cayenne S SOLD
    2008 Carrera S F77 SOLD
    2011 Cayenne S TOTALLED (T-Boned but kept us safe)
    2015 Macan S SOLD
    2015 GT3 - Track Car
    2016 Cayenne SOLD
    2016 Cayenne GTS TOTALLED (Bloody big deer)
    Still looking for 1st Edition Carrera RS book #358.
    Life is way too short to drive boring cars.
    The ones used on the plastic tank are also unique to that tank.
    Alan
    Usually those cars don't have charcol canister. If yours doesn't it will stink of raw gas. Gled
    Yes I'd back the cannister too
    Its up under the dash on the RHS as you look from the front of the car usually held in place by a rubber band
    and its where the fuel tank vapour is meant to vent to
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    In case a pic helps, here is a plastic tank under tray.
    Alan
    Thanks everyone for the help. The car does not have the charcoal cannister which is a good thing as one never came with the car. I appreciate the post from Alan including the picture of the correct bottom pan for the suspension and gas tank. I know need to find that pan as mine is different (thanks Alan, now I need to spend more money!) . I think at this point I need to have small cracks looked into and especially where connections are made. I hope this does not turn into a job where the tank has to be pulled to find the problem.
    I will keep everyone posted once I find the problem.
    RGruppe member 445
    You will have great difficulty in finding that RS style suspension cover
    What it actually is is an 73 style cover where an extra piece was welded in place at the factory to cover fuel line points of the plastic fuel tank
    When I first saw the one on #197 I thought a previous owner had done the add on job but turns out it was factory.
    Removing the fuel tank is very easy once its empty.
    Finding a 73 style and modifying yourself is best bet I suspect.
    Clyde Boyer
  1. Replies: 37
    Last Post: 12-02-2015, 04:41 AM
  2. F/S Original Carrera RS plastic fuel tank
    By Porsche-RSR in forum For Sale: 911 Parts
    Last Post: 01-07-2012, 01:48 PM
  3. Carrera RS plastic fuel tank
    Last Post: 04-28-2010, 12:23 PM
  4. Original Plastic 85litre fuel tank for Carrera RS
    Last Post: 03-27-2010, 03:51 AM
  5. 1973 911 S RS plastic gas tank
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 06-16-2007, 10:38 PM
