Thread: Knocking sound in steering (SWB)
    David Sperow Davz912/911's Avatar
    Sep 2006
    South San Francisco
    Went under the car the other day thinking it was a sway bar mount, or control arm bushings, all look good. I then found the inner tie rod "articulated bush" part # 914 347 057 00 is loose/bad. My question....are they a PITA to replace? do they screw into the rack?
    Dave
    911S registry #1103
    R-Gruppe #513
    1967 912 converted to 2.2
    Period Dune Buggy
    Some drive Porsches' to be seen.....
    I prefer it when nobodys looking.
    They screw into the rack and are held captive by large nuts with steel tab lock washers. However, there's a catch-- the bushings are angled, and so the "articulated bush" is installed in the rack at a certain angle. There is an official factory tool to set that angle. Or fabricate a tool to capture the correct angle before the bush is removed.
    Sep 2006
    South San Francisco
    Thanks 304065....Very good bit of info there. Anybody care to post a pic of the tool?
    Much appreciated!
    Dave
    911S registry #1103
    R-Gruppe #513
    Period Dune Buggy
    Dave, I looked on this computer for a photo of Damon's-- he has one up in NH. There is a photo in the factory workshop manual but I don't have THAT handy at the moment either. . . but I promise you dave, it really does exist, it's about two and a half feet long, fabbed out of steel bar stock with some tall rectangular pieces at the end, with parallel pins that hold a couple bolts that go through the bushings.
    Sep 2006
    South San Francisco
    I believe you I'll do alittle digging on my end too
    911S registry #1103
    R-Gruppe #513
    Period Dune Buggy
  1. Opportunity Knocking :)
    By Edwin Ek in forum Technical Info
    Last Post: 10-13-2013, 10:53 PM
  2. Want Sound?
    By vicrola in forum Other Porsche Passions
    Last Post: 06-25-2011, 06:50 AM
  3. WTB Sound Pad
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 04-22-2008, 02:00 PM
  4. Does this sound right
    By rayuk in forum Technical Info
    Last Post: 07-25-2002, 05:25 AM
  5. Right Front Knocking Noise
    By TripleR in forum Technical Info
    Last Post: 03-01-2001, 06:32 PM
