Thread: Any sucess dying vinyl ?
    Feb 2005
    Montreal, Canada
    Hi,
    Does anyone had good results with spray or liquid dye or paint on vinyl panels and on rear seats ? Red over black or black over red ;
    I'm trying to see if I can make a quick interior from left over parts (1/2 red from a Targa and 1/2 black from a coupe interior) To do a quick resto for a driver car...
    JD
    Nov 2009
    Seacoast NH
    Try SEM products - http://www.sem.ws/. Just returned from Porsche Parade in Savannah and they were recommended by John Paterek for that precise purpose.
    Cheers -
    Hank
    Early S Registry # 1687
    Jul 2008
    South Florida
    If you're handy with a spray gun it's not hard, the surface prep is tedious and must be perfect though. Any oils, fingerprints, etc. must be removed; most upholstery shops use PreCleano followed by whatever cleaning solvent the manufacturer supplies for their paint. PreCleano is a great all around cleaning solvent BTW, like Goof-Off on steroids. It'll actually remove dried overspray without harming upholstery. You should be able to find Parasol Varikote or PPG vinyl dye/paint at bodyshop suppliers, they'll even mix custom colors. Alternatively, check with an upholstery shop, it might be reasonable enough to job out.
    The rattle can products aren't bad... I've done panels to match using both Varikote and Mar-Hyde vinyl paints. Coverage was excellent. All of these products contain solvents that literally bond color to vinyl. If the surface isn't perfectly cleaned though, flaking can occur.
    Good luck!
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Jan 2007
    North of the GG Bridge
    These SEM products are easy to use and offer great results. Seriously!
    I used SEM to take a seat and some door edge trim from tan to black with fine results. Four years later they still look good. Easy too.
    jhtaylor
    santa barbara
  1. Domestic vinyl VS German vinyl???
    Last Post: 04-30-2012, 02:31 PM
  2. Fuel pump dying?
    By 356robo in forum Technical Info
    Last Post: 03-22-2011, 05:51 PM
  3. red shroud dying: water vs. alcohol based ?
    By Kaleid in forum Technical Info
    Last Post: 09-13-2008, 05:12 AM
  4. 73 911 E is dying
    By cmcfaul in forum Technical Info
    Last Post: 03-30-2007, 11:09 AM
  5. MFI fuel pump dying?
    By Type911 in forum Technical Info
    Last Post: 03-25-2007, 05:18 AM
