Page 22 of 44 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 433
  1. #211
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    Bet that was fun. The ONLY car I’d want in that group is that Bahama Yellow VW!
    Reg#2218
  2. #212
    Aug 2010
    And a fun to drive VW at that.
    450 mile weekend and here is the underside. Not one drop of oil. Just a little 3 minute wipe down of dust on the forward facing engine parts.
    I use these then a aluminum washer, then a nylock nut on every 6 and 8 mm stud. Oil leaks are NOT allowed. This engine has 15,000 miles on it.
  3. #213
    Aug 2010
    Next project for both my and Doug's dual oil cooler POLO cars.
    This Mocal thermostat opens all the way at 200F not like the engine and SC ones that opens at 180-190F. Mocal makes a 180 and a 200F thermostat. That way the car only operates on the passenger side cooler past 180ish, and then both coolers fully after 200F.
    Green - 180-200F
    Red --- 200F plus fully open
    The thermostat starts to open and close around 200F progressively as are the engine and SC thermostat. The point is it's doing it's thing 20F warmer.
    The last picture added 1/11/21
  4. #214
    Aug 2010
    I got my parts from BAT. Waiting on the threaded pieces that get welded to the tubes from Elephant Racing. I think I'll have the tubes replated in clear (silver).
  5. #215
    Aug 2010
    Yesterday I picked up and had mounted my 10 hole 6X15 steels with 205/60/15 tires. I'm not sure how much I'll use them as they are heavier than the 6X16 Fuchs. I'll probably show the car sometimes with these as they give the car a little bit of the vintage racer look.
    I also have an extra set of red Firestone letters I might add to the sidewalls.
  6. #216
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    ...sometimes in winter is is a better choice to use the heavy boots..
    but
    is there still space for the steelies with the calipers?
    br
    stay safe&healthy
    haul
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
  7. #217
    Aug 2010
    haul,
    In the winter the car is on jack stands, wheels off to take the weight off the suspension.
    I spent the better part of a day with a compressor and grinder getting the welds smooth with about 3 to 4 mm caliper clearance.
  8. #218
    Mar 2012
    Kansas City
    Those wheels are pretty cool Chris. Love to see pics on the car!
    Reg#2218
  9. #219
    Aug 2010
    Here you go. The Sun's angle didn't pick up the wheels very well. I'll reshoot later. I just rolled it out of the garage. After a little road time I’m guessing it will settle a little. These tires are about a 1/2 inch taller than my 195/55/16’s. I have 5 mm spacers to clear the front Brembo’s. I think I’ll take them off for the rears.
  10. #220
    Aug 2010
    Quote Originally Posted by Chris Pomares View Post
    We are leaving the soft lines off. Thus a smaller and cleaner install. The 200F thermostat and duel female an12 parts are 210 mm (8 1/4 inches) long. The weld on end pieces have gone from 30 mm by 1.5 to the an12 weld on parts so we can use the duel female an12 parts. We will make custom support brackets and a small tray to catch any seeping oil if there is any.
  3. Polo Engine Dyno Results
  4. What is a POLO engine?
