Results 1 to 10 of 15
Thread: Help with solex PI 40 fuel pump set up
    Oct 2010
    Denmark
    I am startnig to figure out , how to fit my solex, so
    Can anybody possible help with a drawing or know someone who can help with konfiguration on the pump + hoses, what goes where..?
    NB! I will not use the mecanical pump, and I have a 1965 911 with original engine
    with ca. 185 HP
    I know duel in holland use one Bendix/facet fuel pump in the front( where the gasheater normaly was) + 2 pierburg cylindric fuel pump in the engine area, one for for each side tribbel solex.
    But.... how is it set up? does they remove float + float valve in flotbowl on mainfold or?
    and is it nesseray with return hose to gastank?
    your help is much apriciated
    Lars
    The pump in the smuggler's box delivers fuel to the engine compartment where a "T" is used to divide the flow to the fuel inlet lines that supply the spill tubes (fuel delivered to the fuel lines with the banjo fittings.) The fuel that drains into the float bowl on each intake manifold drains out the bottom of the bowl and a Pierburg pump sends this fuel back to tank (one pump per maniflod); the floats are removed from the bowls. The rate of flow must be regulated so that there isn't too much flow delivered to the spill tubes; when I recently test ran a set of Solexes I used an adjustible pressure regulator after the main supply fuel pump to adjust rate of delivery to the carbs.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Oct 2010
    Denmark
    Thanks Paul
    the 2 return pump, are the joined together i one hose back to the tank? or ?
    does the hose run where? in the tunnel where the stel fuel line runs ?
    does you connect it to the fitting on the tank, where the gasheater normaly were?
    rg.Lars
    rg.
    Paul,
    Is the routing described above the stock set up or the reverse set up?
    Scotty
    This is the standard fuel circuit.
    A picture is worth a 1000 words. Thanks for that diagram Chris_seven! Can you tell me where you found it? I'm a new 65 owner and need to get some workshop manuals.
    Oct 2010
    Denmark
    thanks
    I dont use the mecanical fuelpump, so It would be super if I could get a dreawing that shows the routing with the 2
    ekstra perburg pump
    rg.Lars
    The two Pierburg pumps would have their output hoses joined with a "T"-fitting and the fuel would then return to the tank either at the fuel nipple for the auxiliary heater or into the top of the tank via a vent pipe. If the return is routed through the tunnel then a rigid line would be best for safety purposes. This is what I think would be best subject to input from others.
    Paul Abbott
    Early S Member #18
    530.520.5816
    The standard set up doen't have any fuel return- the fuel is simply re-circulated into the manifold the Pieberg pump takes fuel from the reservoir and into the fuel rail which in tuurn fills up the spill tube. The fuel falls through the spill tube and back into the reservoir. though a fuel rail in the manifold.
    There is a comment in Ludvigsens book that this 'was to aid fuel vapourisation'. I think that this comment expains some of the issues with this set up.
    If you try to return the fuel to the auxiliary heater outlet then the pump will need to overcome the head of fuel in the tank and this may be an issue depending on the pump capability.
    If you ise the recirculating pumps to pump the fuel back to the tank then you will have to decide how to put fuel into the fuel rail and fill the spill tubes.
    The Pieberg cylindrical pumps used by Duel are quite small flow and also relatively low pressure - I think they are rated at 2.5 psi.
    In general terms pressure is the enemy pf this system. The spill tube design will only operate correctly when there is a consistent head of fuel. If you develop a pressure drop across the spill tube it will mess up the jetting but if the pressure drop were constant you maybe able to make allowance but if the pressure varies so will the fueling.
    Oct 2010
    Denmark
    What will be the most secure/safest way to go?, I am looking for the most driveable/safest solex setup, because I use the car a lot, also on long trips in europa. Does everybody remove the floats? + float valve?.
    I`m looking for the most simple sollution, because if I have a breakdown in one of those trips, the chances for a skilled porsche/solex mecanic arround, it very small :-)
    They pirburg pumps come in 2 version 1. 2.5-3.5 psi 2. 4-5.5 psi
    How much pressure is correct for the solex?
    thanks again
    Lars
  1. FS: Pierburg Solex Fuel Pump
    By John Straub in forum For Sale: 911 Parts
    Last Post: 12-31-2013, 04:19 AM
  2. Replies: 3
    Last Post: 03-09-2013, 08:14 AM
  3. Solex Fuel Pump Parts
    By John Straub in forum Technical Info
    Last Post: 11-03-2008, 09:43 AM
