Thread: Re-torquing HE/exhaust nuts.
    Hi All
    I'll preface this by stating I've tried the search option & was unsuccessful in my quest. I am also sure I am missing something very obvious to the more experienced members of the board.
    Re-installing & torquing the barrel nuts looks as though it will be straightforward enough. My question is; how do you guys get reasonably accurate torque values on the remaining nuts? They (a couple of them at least) are somewhat less than accessible even during dis-assembly.
    Any advice would be greatly appreciated. Thanks in advance.
    Cheers
    JB
    Although I've never used a torgue wrench on heat exchanger nuts I don't see why you couldn't, nor are they what I'd call inaccessable. The barrel nuts are reached with a 3/8 drive 8" long 8mm allen socket or 1/2 drive if really tight. The 13mm standard nuts are easily reached with a long 3/8drive extension and 13mm universal socket. The one 13mm under cylinder 4 is accessed with a 13mm offset box end. The standard torque for 8mm studs is about 18 ft.lbs.
    Many Thanks & much appreciated. I probably was a little overwhelmed by the apparent lack of access.
    Cheers
    JB
    That's true, it can look unaccessable, but when you've spent 50 years buying tools there's not much you can't get to, and the newer the car the worse it is. That's why the Snap-On truck is such a wonderful place to kill some time,,,,and money!
  1. Nuts and Bolts
    By Richardnew in forum Technical Info
    Last Post: 02-03-2013, 01:50 PM
  2. torquing rear stub axle castle nut
    By hoffman912 in forum Technical Info
    Last Post: 05-11-2012, 06:57 PM
  3. Gas Burners - what to use for nuts?
    By W6CZ in forum Technical Info
    Last Post: 11-30-2008, 03:01 PM
  4. Exhaust Experts Unite - need help for racing exhaust !!!
    By RPMClassic in forum Technical Info
    Last Post: 09-06-2006, 06:06 PM
