Results 1 to 9 of 9
Thread: Wanted: One 915 LSD Drive Flange
    WTB a single course spline 915 LSD Drive flange. 110 mm dia. with 4 10mm bolts & 2 dowel, 103 mm total length and 61mm plunge depth from end of splines to the seal shoulder. A 915 casting # is sometimes readable. I have a single 901 LSD drive flange if someone needs one. It will fit in a Mag box. Gordon
    Bump, someone must have an odd drive? Thanks Gordon
    Banned
    Nov 2004
    Scottsdale, AZ
    That's an oddball- course spline up to '75; most were fine spline.
    You don't have any later 6 bolt course spline LSD flanges do you? I could use some of those.
    Bump, still looking. Gordon
    Aug 2007
    Phila Pa. area
    frank, are you saying lsd had fine splines up to 1975/
    Mike
    Banned
    Nov 2004
    Scottsdale, AZ
    That's been my experience.
    Hey Gled,
    FWIW,.....I've made one by machining a non-LSD coarse-spline flange. Worked perfectly!!
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    All early LSD's for Mag cases (911/915) had coarse spline. If they had coarse splines they required the +5mm plunge depth. Late LSD's had a drive flange with a flat bottom at the spline end and they were +5mm and were interchangable in open diffs. The only exception to the fine spline LSD is 76-77 Turbo that required a +5mm hollow end drive flange. You could machine the end of a flat bottom drive flange hollow or machine off the nipple on the threaded piece inside the diff. gled
    Aug 2007
    Phila Pa. area
    This has been my expereince also
    Mike
    Mike
  1. WTB: SSI thin flange, non MFI
    By eaton in forum For Sale: 911 Parts
    Last Post: 03-01-2014, 05:56 PM
  2. WTB - 901 Axle Flange
    By ryanmadson in forum For Sale: 911 Parts
    Last Post: 01-31-2009, 04:53 PM
  3. WTB drive flange for early Turbo
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 01-15-2008, 07:17 PM
  4. Wanted 1972/1973 Factory Color Charts..right Hand Drive Arm Rest..
    By execmalibu in forum For Sale: 911 Parts
    Last Post: 09-23-2005, 06:26 PM
  5. thin flange ssi's
    By joelrkaplan in forum Technical Info
    Last Post: 12-05-2003, 03:58 AM
