turns out i will not be doing what i intended when i picked this up so i'm passing it on
from the original listing:
Quote:
930 case
3.2 SS short block
New 10.5 JE pistons set-up for twin plug
New LN Engineering cylinders
Arp rod bolts
factory steel head studs (24)
New alternator
New hardware kit
New oil return tubes..etc., etc..
what's included: everything but intake and exhaust
what it needs: rebuild/refresh/twin plug (or not) heads, decide on cams accordingly
it's halfway completed and before it can go any further a decision needs to be made whether to twin plug the heads or simply clean/refresh them. this will also affect the cam choice. heads and cams are stock early sc at the moment
p's and c's alone are worth $5k.
located in the dc metro area
asking $5.5K for everything
current condition:
