Results 1 to 10 of 17
Thread: 911/83 engine case repair
    Feb 2011
    Spain
    Hello,
    I have a nice matchings number Porsche 911 Carrera 2.7 European version. The car is great. Nevertheless, the engine case needs to be repaired due to a small fissure. The shop tells me at it will be much better to replace the engine case with a Porsche 911sc aluminum case. Will the car loose value with this replacement? What would you do?
    Regards!
    If the 911/83 is in a '73 Carrera RS, I would tend to say that replacing it with a 911SC case would de-value said RS...
    The cases are not interchangable. You would need the SC crankshaft since the bore spacing is different. I think the 4 bearing cams would be needed and the head stud spacing is different so you would need the SC heads. This would significantly devalue the car.
    Jun 2011
    Western US.
    a little off topic but, are the 911/83 engine cases ONLY from 73 RS's?
    I thought that they used those cases in ROW 74-75 Carreras as well?
    No, ROW 2.7 Carrera's had 911/83 as well.
    Jun 2011
    Western US.
    That i knew...
    what I was asking is...the 911/83...used ONLY for the 73RS or for other non-73 911s as well?
  1. Bureau of Auto Repair Engine ID Sticker???
    Last Post: 02-07-2022, 11:55 PM
  2. FS: Repair Parts for SWB engine grill
    Last Post: 09-03-2013, 04:00 AM
  3. Engine Harness Repair
    By leecarrera in forum Technical Info
    Last Post: 03-25-2009, 09:30 AM
  4. Replies: 2
    Last Post: 11-20-2008, 11:50 PM
  5. FS: Aluminum Engine Case - Type 901/01, Engine 902409
