Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 911/83 engine case repair
  1. #11
    Jun 2011
    Western US.
    SO any 74-77 2.7 911 will use this case...is that correct?
    I DO appreciate the clarification on this.
  2. #12
    Nov 2002
    Fremont, CA
    911/ 83 = 2.7 Mechanical Fuel Injection. Serial numbers 663xxxx= 1973 RS, 664xxxx=1974 RoW Euro Carrera, 665xxxx=1975 RoW Euro Carrera, etc.
    911/83 is NOT for ANY CIS Car= 74-77 911/911S/USA "CARRERA"
    My replacement case will work for any 1973-1977 2.7L car, there are no numbers in it. My case could be used in a 1975 911S, but I don't know why you would. I would use it for a 73RS that no longer has the original engine, or at least a '74-76 car with the MFI (911/83) engine originally
    scott kinder
    kindersport@gmail.com
    Registry #614
  3. #13
    Peter Kane
    '72 911S Targa
  4. #14
    Jun 2011
    Western US.
    Thanks guys....mystery solved!
  5. #15
    Quote Originally Posted by Flieger View Post
    Oh.
    RSR used 911/83 based on RS homologation, no? No others.
    Quote Originally Posted by varunan123 View Post
    No,they did not use that case type on ST's or RSR's.
    raj
    Whoops. That is right. The type numbers were different. I was just thinking about the basic case architechture (since he had asked about SC case I was just thinking about that side of things, not type numbers). But then, any MFI car with a 7R would have had the same case.
    I do know that they made some cases in Aluminum for RSR, then made the 3.0 RSR case with a wider head stud spacing to help longevity (more metal between cylinders).
    Silly me.
  6. #16
    Feb 2011
    Spain
    Thanks for the input! It solves my question, so any 2.7 case will do the job and I should keep the old case so I won't devalue the car.
    Nov 2010
    West Palm Beach, FL
    Save the case,
    How bout fixin the case!! George at Ollies can do the impossible to most any Porsche engine block (case). This CRACK is a simple fix, might cost some scoot but..................
    Kevin
  1. Bureau of Auto Repair Engine ID Sticker???
    By bob tilton in forum General Info
    Last Post: 02-07-2022, 11:55 PM
  2. FS: Repair Parts for SWB engine grill
    Last Post: 09-03-2013, 04:00 AM
  3. Engine Harness Repair
    By leecarrera in forum Technical Info
    Last Post: 03-25-2009, 09:30 AM
  4. Replies: 2
    Last Post: 11-20-2008, 11:50 PM
  5. FS: Aluminum Engine Case - Type 901/01, Engine 902409
