Thread: Engine case dimensions ?
    Hi,
    I'm about to drill bigger holes for cylinders in my 2.4 S engine case.
    I've got 6 cylinders+pistons from a 2.7l and i want to install them.
    My problem is that i've destroyed my 2.4l cylinders and i don't know what is the tolerance between the engine case and the cylinder.
    So is there anyboy knowing the diameter of the engine case holes for a 2.7l ?
    Rgds.
    Freddy
    Feb 2003
    Los Angeles
    From memory, the 2.7 cylinder spigots should be 97 mm. The 2.4 cylinder spigots are 92 mm.
    I hope someone with reference books can confirm.
    Good luck.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Thks BERT for this reply.
    97mm is ok.
    But Tolerance for the engine case ? +/- ?
    I think the dimension is 97,2 +/-0,05 but not sure ?
    Rgds
    Feb 2003
    Los Angeles
    Sorry. I don't have a spec book for the 2.7 engines.
    Bert Jayasekera
    R Gruppe #167
  1. 67S NOS 2.0 Engine case
    By Rennman in forum For Sale: 911 Parts
    Last Post: 10-01-2010, 04:44 PM
  2. FS: 911 T Engine Case
    By jhora in forum For Sale: 911 Parts
    Last Post: 09-13-2009, 08:06 AM
  3. Where did my engine case come from?
    By garycox in forum General Info
    Last Post: 08-08-2009, 07:54 AM
  4. Replies: 2
    Last Post: 11-20-2008, 11:50 PM
  5. FS: Aluminum Engine Case - Type 901/01, Engine 902409
