Results 1 to 2 of 2
Thread: MFI air flow at 300RPM
    With a 2.4S how much air flow, on a synchrometer ,should be pulling at 3000RPM's? At idle, my car pulls about 5 1/2 KG/H around 950 RPM, but at 3000 I show around 18 KG/H. The example in the Manual indicates an average of only 11.5. That example could be because it's not a 2.4S, but my reading of 18 KG/H seems excessive.
    I should point out that my air screws are around 1 1/2 to 2 turns out.
    Brian, sent you an e-mail
  1. CFM flow for a 911S head ?
    By 911E&26R in forum Technical Info
    Last Post: 01-18-2010, 08:25 AM
  2. Oil Cooler Air Flow Question
    By jameshtaylor in forum Technical Info
    Last Post: 10-23-2009, 06:37 PM
  3. Restoration costs vs Cash flow
    By Original Poster in forum General Info
    Last Post: 08-19-2009, 01:53 PM
  4. Fuel Pressure and Flow
    By TOL-S911 in forum Technical Info
    Last Post: 06-02-2009, 10:34 PM
  5. Oil Flow Rate
    By CSP-Will in forum Technical Info
    Last Post: 11-22-2006, 07:07 PM
