Results 1 to 7 of 7
Thread: WTB, chrome headlight screw!
    Stripped out my screw holding the bottom of the headlight to the fender. Anyone got a spare?
    TIA
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Bump! TIA
    10 sec 67 VW
    Jan 2003
    UK
    Dave - is this from a Bosch Euro H4 ?
    If so, I probably have one if you don't have any luck closer to home.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Here's one source, there may be others:
    http://www.sierramadrecollection.com..._detail&p=2137
    John Schiavone
    Connecticut
    Thanks John, but if you look closely that is black, not chrome. Thats all Stoddard had as well.
    Andy, yes it is just a standard H1/H4 screw. Can you help out?
    Thanks!
    10 sec 67 VW
    Jan 2003
    UK
    I've got these - either with or without the nylon washer & rubber/plastic spacer:
    If this is what you need pm me your address & I'll stick one in the post tomorrow morning.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Dave, usually what strips out is the stamped threaded nut in the bucket, it is very fragile. Check with a 5 mm x .8mm tap to see if that stamped threaded piece still has threads in it. We fix a lot of those by mig welding a 5mm nut on the stamping.
  1. WTB: Chrome Headlight Surround
    By Neunelfer in forum For Sale: 911 Parts
    Last Post: 11-21-2012, 06:56 PM
  2. headlight adjustment screw crimps
    By hoffman912 in forum Technical Info
    Last Post: 02-28-2012, 07:20 AM
  3. WTB: one chrome headlight rim.
    By jameshtaylor in forum For Sale: 911 Parts
    Last Post: 08-18-2010, 09:57 AM
  4. 2 screw chrome horn grills
    Last Post: 11-09-2006, 05:22 AM
  5. WTB: Chrome Horn Grill, 2 Screw, Drivers Side
    By BAPhotowerks in forum For Sale: 911 Parts
    Last Post: 07-31-2006, 01:02 PM
