Results 1 to 9 of 9
Thread: 66 vs. 67S Engine
    66 vs. 67S Engine
    I am looking to upgrade a 66 to 67S or higher specs. What are the differences in components: carbs ,cams, valves,P+C's, ignition, crank, rods, etc? Checking to see if it is more cost effective to locate a complete engine.
    50/50
    Main differences are
    Cams
    Heads/Valves
    Pistons
    The carbs and disty are also a bit tweaked. And I believe some of the internal engine components (crank, rods) were checked more for flaws and perhaps treated in some way to strengthen them.
    Probably more effective to find the parts and convert your existing engine. Buying an entire S engine is pricey.
    Is the crank the same (counter weighted)? What are the valve sizes? Also the carb bores?
    Apr 2004
    Valves: 42/38
    Lift: 11.6/10.3 ( 11.55/10.57 - 901/05)
    Light alloy forged pistons instead of cast - nitrided rods.
    Little end bushes solid copper alloy instead of rolled bronze
    Venturis were 34s
    Then on to the brakes and sway bars, gear ratio...
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    Thanks John
    What are the differences with the crankshaft?
    Apr 2004
    Not aware of any difference. Both were counter-weighted.
    The crank on the T and the 912 were not - but interestingly the heads on the T were the same as on the S.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    Quote Originally Posted by John Fusco View Post
    912? The 912 did have a counterweight crank (too) but is of course 4 cyl.
    Richard
    Apr 2004
    I stand corrected.
    Thanks Richard.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    Yes, the crank is counterweighted. The differences are spelled out very nicely in Paul Frere's book.
  1. Replies: 8
    Last Post: 09-01-2012, 05:47 PM
  2. Fleebay Engine: 1968 Porsche 911S Engine 901/02 Weber IDS 40 Carbs 911 S Motor
    By Doc72 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 08-31-2012, 07:09 AM
  3. Replies: 23
    Last Post: 08-30-2012, 06:01 PM
  5. Replies: 33
    Last Post: 11-02-2005, 03:13 PM
