Thread: What kind of CAMSHAFT is this???
    Hello,
    What kind of CAMSHAFT is this please??? Can't find it in Waynes book.
    901.105.109.0R
    AF 2
    12.12.67
    It came out of a 901/03 engine magnesium case which has aluminium cylinders and S pistons....
    Thks,
    I
    Member clesch's Avatar
    Jun 2011
    Austria
    Could be a factory option 911R part as indicated by this thread:
    http://www.elfertreff.de/showthread.php?t=17854
    Apparently it was also part of the 2.0S "Competition Kit" (901.100.907.00) and the "Rally Kit Option 9552".
    Restoration newbie.
    Jun 2007
    San Francisco
    Does it have anything stamped into the threaded end?
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    May 2006
    CT
    That cam has the stamping of a 911L cam. Same grind as the E without the MFI drive
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Stamping on the threaded end is:
    05
    In the middle is:
    901.105.109.0R
    More to the right:
    AF 2
    Other side in the middle:
    12.12.67
    May 2006
    CT
    I believe the "05" refers to the last two digits in the part number. These are different than the casting number which is cast into the body of the cam. The "05" refers to the L cams which have the same grind as E cams (without the MFI pump drive).
    Tom Butler
    1973 RSR Clone
    1970 911E
  1. FS: 2.4T Camshaft and Camshaft Case
    By carlito in forum For Sale: 911 Parts
    Last Post: 02-18-2014, 12:54 AM
  2. Please help ID this camshaft
    By Ramany in forum Technical Info
    Last Post: 12-04-2009, 05:05 AM
  3. Camshaft id help
    By JHunter in forum Technical Info
    Last Post: 01-29-2008, 07:42 PM
  4. Camshaft sources?
    By admin_old in forum Technical Info
    Last Post: 12-17-2002, 06:09 PM
  5. RE Camshaft Specs
    By rfng in forum Technical Info
    Last Post: 12-15-2000, 09:02 AM
