I have spoken with 2 reputable shops on using 2.2 Mahle cylinders in a 2.0 case. One says it can be done without opening the case. The other says the case hase to be opened. Didn't discuss modifying the cylinder. Anyone with experience with this?
You need to do some searches here and on Pelican, this topic has been covered before. I think you should also buy a copy of both Bruce Andersons book and also Wayne from Pelican's engine rebuilding book. Lots of good info on mixing and matching in those books.
I think the 2.2 jugs may fit in the holes, but the sealing method to the head is different, so machining is required.
2.2 will fit 2 liter case without opening 2 liter but if your going to use 2 liter heads you will have to modify them. If using 2.2 and some later heads your GTG.
Early 911S member #166
Use 2.2 or 2.4 heads and sell the 2.0 heads. The combustion chamber shape was improved and will match the pistons.
The shape of the 2 ltr piston and combustion chamber (head) are not the same as a 2.2 piston and head you would need 2.2 heads.
The 2.2 case has the piston oil squirters for cooling. (Corrected) The aluminum case is also a stronger unit then the mag case as per Chris.
Curt Hammill
911S#2032
http://www.linkedin.com/pub/curt-hammill/38/347/849
1969 911E 2.5ss twinplug
http://www.911e.org/microsite.php?119200483
1997 993C2s
Audi 1983 groupB rally tq-sport
http://www.1-buc.de/site/content/2_news_1006.html
2.2 case is Mag not Al. Chris
- Chris-Early S Registry#205
- '70 911S Tangerine
- '68 911L Euro Ossi Blue
You can use the 2 L heads - but they will have to be fly cut for the 2.2 app.
At least I know you can do it using E p/c's
Du must schwein haben
901/05 #305701
Bultaco Metralla 62 M8
1968 BMW R69S
Early911SReg #606
The compression ratio will be very low since the combustion chamber of the 2.0 heads is much bigger than the 2.2 liter heads.
My car goes pretty well.
901/05 #305701
1968 BMW R69S
Early911SReg #606
