Thread: Interior Question : Qtr Window Frame Seal to Body ?
    joe912 joe912's Avatar
    Dec 2004
    Metepec , Edo. de Mexico
    I did a research towards this topic but find nothing : Is there any Seal or gasket (LH/RH) between the "C" Pillar and the little "Triangle" that attaches with 3 Screws the Frame to the Body on the Side of the Hinge ?. I noticed that some cars have them and some don`t . Which are the dimensions, thickness and function of this part ? . I Could not find it in any: Porsche , Stoddard nor Pelican Part Catalogue or Exploded views.
    Joe 912
    '68, 912
    Mexico
    Early 911S Registry # 1918
    There is a plastic spacer about 1/8th" thick that is sometimes used between the qtr. window latch and the C pillar. They are used to help the qyt. window latch go "over center" if needed. At least that is when I use them.
    Jun 2011
    Los Alamos, NM
    Is this the spacer in question?
    This is a photo of the hinge on my 68 with the plastic spacer underneath it just before I took it off. If that's what you're looking for, I have that part in a plastic baggie. I can photograph it and give you dimensions.
    <table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/a9oFgGiqjrfSmWzGLCnk0Q?feat=embedwebsite"><img src="https://lh5.googleusercontent.com/-b-x-vGfOMtw/TiemhUBwF4I/AAAAAAAAAKE/edGr7pr5xZY/s400/DSCN0276.JPG" height="286" width="400" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/107685368595078804853/1106Porsche911OriginalState?authuser=0&feat=embedw ebsite">11 06 Porsche 911 original state</a></td></tr></table>
    --Von
    Von Whitley
    Los Alamos, NM
    1968 Polo Red coupe (under reconstruction)
    1968 Metallic Silver SWT (under reconstruction)
    Registry number: 2016
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    You can still get them new from Porsche, or at least I did about a year ago, don't have PET in front of me for a part number sorry, but if you need it I can check.
    As Ed said it helps the latch go over center, with new rubbers fitted they can be hard to latch, but I can imagine once the rubbers settle down you'll need the spacer to achieve a water tight window.
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    Sierra Madre has them listed which is what I believe your looking for.
    http://www.sierramadrecollection.com..._detail&p=6510
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
    Available from any Porsche dealer, not just Sierra Madra p/n: 901.543.491.21
  1. Schutz/Under body seal on inside of bumpers?
    By 19-911-65 in forum Technical Info
    Last Post: 02-18-2016, 03:52 PM
  2. rear center pane to body seal
    By Cliff in forum General Info
    Last Post: 06-27-2011, 05:26 PM
  3. windsheild frame seal
    By freezing14 in forum Technical Info
    Last Post: 11-27-2009, 05:09 PM
  4. Help with rear bumper-to-body seal
    By Sandwich Boy in forum Technical Info
    Last Post: 08-13-2009, 06:08 AM
  5. Fender to body seal material
    By adam912 in forum Technical Info
    Last Post: 10-05-2005, 11:44 PM
