Results 1 to 9 of 9
Thread: repair and restore of front hubs
    May 2010
    Sanford, NC
    I am working on cleaning and restoring the front hubs. I soaked both in parts washer fluid that is rated safe for aluminum / aircraft parts. Most of the crud has come off, but there remains two issues: (1) how do I get the metal shiny again? Polish? With what?, and (2) there appears to be corrosion / bubbly stuff in some spots. Should I just grind this off with a dremel?
    Thanks. Rick
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Depends what your after, you can hit the corrosion with wet and dry but then the metal is unprotected, you options are paint with something like VHT or push your studs out and powder coat.
    If your really after an original look, push your studs out, media blast and have them re anodized and put your studs back in.
    Sep 2006
    Eagle, Idaho
    Front hubs were not coated or plated with anything. If you elect to powder coat ( not at all a good idea in my opinion ) you'll incur extra hassle & cost because you would have to mask the surfaces that are in contact with the brake rotor and where the wheel bolts against the hub, as well as plugging the open ends so you can install bearings. Under no circumstances should the entire exterior of the hubs be powder coated.
    Anodizing might make you feel better, but is completely unnecessary..........as I said, original stock hubs were raw aluminum castings. Spray them with GIBBS for long-term corrosion suppression, let sit overnight, remove excess and install.
    Attached a photo of my hubs after I bead blasted them with a very fine material that was left in the machine long after it should have been changed. Open ends were masked to cover the inner bore. Any marks, smudges & discoloration are strictly from handling with dirty hands.
    Good luck
    May 2010
    Sanford, NC
    thanks for the help. I will keep working on the surface and probably not powdercoat.
    Rick
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Soda blast them.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    We strip, blast and anodise them. Most we see over here in the UK are in pretty bad condition. We did get quite far into having them re-sand cast but insurance of the items became the problem. Now we are going to CNC machine some from billet.
    Alan
    Just to make the process more complicated. I'm throwing in another step, push out the studs, re-black the studs, strip/drip, blast, tumble and no anodize.
    Jan 2011
    DFW TX
    Is there a a solution such as sleeving for worn bearing seats? I picked up an otherwise perfect pair of hubs today that spun the inside bearings. They might be destined to become lamps...
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Quote Originally Posted by M_deJong View Post
    If they are not too much out of measure I'd take Loctite and glue the bearings.
    The next time you want to change them you'll need heat to dismantle.
    Uli
  1. FS: 911 - 914-6 Front Hubs - Extremely Clean
    By Neunelfer in forum For Sale: 911 Parts
    Last Post: 03-06-2014, 08:49 AM
  2. FS: More Later 911 Front Hubs (Hub Centric)
    Last Post: 03-06-2014, 05:19 AM
  3. WTT: 40 mm front hubs to 47 mm ones
    By drmrfi in forum Free, Trades, and Swaps
    Last Post: 05-06-2013, 10:16 AM
  4. WTB 69-73 front hubs
    Last Post: 11-19-2008, 01:15 PM
  5. Picture of restored front hubs?
    By WM711 in forum General Info
    Last Post: 03-06-2007, 02:31 PM
