Thread: Fuchs Rim Repair?
    Fuchs Rim Repair?
    Calling on all the rim experts. Can a crack in a Fuchs rim be repaired? The crack is in one of the spokes. Not the outer rim. I'll try to get some pics.
    A.T.
    A.T.
    Early 911S Registry Member #500
    Ask Harvey Weidman of Weidman Wheels
    530.534.7903
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Oct 2010
    Florida
    Send it to Harvey
    Richard Newton
    Vintage Motorsport Magazine
    In answer to your question, yes it can be repaired. We have done it quite a few times and also use a weld rod with a similar metal to the fuch thus minimising the visual weld if the wheel is being re-anodised.
    HTH
    Alan
    Thanks, guys. Luckily I have a second set of rims that should work for now. When I make the switch I'll get some detailed pictures and post them.
    A.T.
    A.T.
  1. Ques- Has anyone seen this repair before? Any help pls.
    By S Jellybean Car in forum Technical Info
    Last Post: 09-25-2008, 09:01 AM
  2. Tank repair
    Last Post: 07-23-2007, 01:05 PM
  3. Crest repair
    By Bummler in forum General Info
    Last Post: 05-19-2006, 11:32 AM
  4. fuchs repair?
    By Rico in forum General Info
    Last Post: 03-23-2006, 06:44 PM
  5. fan repair
    By preS in forum Technical Info
    Last Post: 08-17-2005, 06:12 AM
