Results 1 to 9 of 9
Thread: 960035
    I saw this very early S case on the samba.
    http://www.thesamba.com/vw/classifie...php?id=1197096
    No affiliation.
    Richard
    Oct 2008
    Burford, ON, Canada
    Not sure of the value of the EMPI parts, but the case might be worth a good bit.
    I got a reply on the build # : 5322 from the looks of it.
    Quick response from the seller.
    Oct 2010
    Denmark
    Hi
    I have the same empi kit on my matching 1965, fitted in early 1970`s it runs like a canonball, a lovely short stroke engine.
    Lars
    Apr 2008
    Virginia's Blue Ridge
    Lars, do you know what type of compression those EMPIs yield?
    Those EMPI pistons are very cool. Along with the compression, what CC motor results from using these pistons? I assume HP would move to 180-190 territory.
    Apr 2008
    If I did the math correctly, displacement with the 88mm EMPIs should be a hair above 2.4 The 89mm Mahle's made 2.5 (hair under).
    EMPI 88mm: 2408.5 cc
    Mahle 89mm: 2463.6 cc
    Oct 2010
    Denmark
    Hi
    I`m not sure about the compression but the dynotest says 182 HP on the rear wheels and 215NM at 4200 rpm,
    I will be back with new numbers when my rebuilded solex pI 40 is fitted, they got 34 mm venturi, drilled to 42mm, and 42 mm buttefly. Hope to gaine about 10 hp
    rg.Lars
    Oct 2010
    Denmark
    Hi again
    Wonder if the cylinder also is empi, they must have empi logo stamped into the outside wall. My cylinder have this stamp, and they have also 1 ekstra cooling "ring" compared to the original biral porsche cylinder.
    Lars
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Lars, that sounds like a terrific motor!
    RGruppe #183
