Thread: Mirelli S112AX vs S112BX
    Can anybody enlighten me on the differences between the Mirelli S112AX (used in '69) and the Mirelli S112BX (used in '70)?
    Are they interchangeable? How about the cap (I assume they are both the 'long' version) and rotor?
    And finally which Mirelli model is it that requires the short cap?
    Dirk Janek
    1970 911T 3.0/915
    Anybody to share some insight on this?
    Dirk Janek
    1970 911T 3.0/915
    As far as I know the only Marelli using a short cap was the new style version starting in 72 #5-010-974. I never really looked at the distributor numbers back in the early 70's but I can't think of any reason they wouldn't interchange. A slight change in advance curve, for example, would require a new part number.
    Port Macquarie, Australia
    Dirk, your 3.0 doesn't use a Marelli...
    John Forcier
    EarlyS #1987
    Restoration Saga
    Quote Originally Posted by Fishcop View Post
    True... however my car's original engine does have a S112BX installed. I am currently sorting through the boxes of extras that came with the car. This includes a S112AX and what I believe is a NOS long cap and rotor (that I understand are somewhat rare). Thinking (very) long term about the possibility of rebuilding the 2.2 and I was wondering if the S112AX would be a suitable backup for the S112BX.
    As always thanks for the response John, doesn't seem to mater where I post a question - you are always the first to offer help.
    Dirk Janek
    1970 911T 3.0/915
  1. FS: MAGNETI MARELLI S112AX Distributor
    By jordan67911S in forum For Sale: 911 Parts
    Last Post: 08-09-2013, 12:31 PM
  2. FS: Marelli distributor S112AX
    Last Post: 10-25-2009, 07:40 AM
