Results 1 to 8 of 8
Thread: Is this repairable?
    Jun 2011
    Mound, Louisiana
    Question Is this repairable?
    Original aluminum pressure plate out of my 72 S. Two of the three straps that secure the plate to the housing are broken... (and I wondered why it had a slight vibration. )
    Quote Originally Posted by 72 911S Targa View Post
    possibly, but why bother. they're cheap enough. I must have half a dozen, if you need one. Don.
    Jun 2011
    Mound, Louisiana
    Thanks. I didn't know they were still available....
    I have had a hard time finding the ALUM. unit most that I found new were steel. Best of luck,get all of that rotating stuff balanced by a trusted shop I recently had to pull my engine to sort out a horrendous flywheel vibration. Steve
    oops. my bad. I thought you meant aluminum body. I didn't realize the S used a coated aluminum friction disc.
    Jun 2011
    Mound, Louisiana
    The disk is steel, but the housing is aluminum. I replaced it with an all steel unit. I did weigh them and the aluminum one is a little better than 3# lighter. Although not a killer, quite significant I would think. That is the reason I was asking. Thanks.
    Quote Originally Posted by chiroracer View Post
    is this what you're looking for?
    http://forums.pelicanparts.com/porsc...0-86-911s.html
    Jun 2011
    Mound, Louisiana
    Quote Originally Posted by haycait911 View Post
    So I guess some one is reconditioning them? That's great! I'm in!
