Thread: Webers and solid engine mounts
    I've searched for previous threads but haven't found a good answer to these:
    Do solid engine mounts lead to flooding the float bowls?
    Has anyone used soft mounting provisions to isolate the carbs from vibrations?
    I know what PMO recommends regarding solid mounts for engines.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Quote Originally Posted by 1QuickS View Post
    You mean rubber mounts between the manifolds and the carburetor bodies?
    -Marco
    TLG Auto: Website
    Do solid engine/transmission mounts with the chassis cause issues other than fuel frothing in the bowl with resultant fuel delivery variations?
    Has anyone had experience mitigating the effects of solid engine/transmission mounts by using soft gaskets (rubber/Viton) between the carb and the top of the intake manifold?
    Paul Abbott
    Early S Member #18
    530.520.5816
    I'd be more worried about the chassis developing cracks with the solid mounts. Unless this is for a race car that is constantly checked. Even so vibration is really damaging, i've seen transmission housings crack. You need a little give somewhere. Apart from that I can't imagine it affecting the carbs.
    Paul, in the "old" days of racing a 356 in E/P, since we did use a solid transmission hoop mount (to reduce lateral trans movement) we used to use a "thackery" washer to allow the carb to float slightly and hopefully to reduce the frothing you mention. This washer was in essence a miniature coil spring installed between the nut and carb base (longer studs required).
    I know these short coil springs Ed but now I know their name. :-) I guess you used a rubber gasket to maintain vacuum seal when carbs were "floating".
    I have a customer with oil dilution by fuel and am searching for possible causes; the carbs look good but there isn't a pressure regulator installed and I doubt float levels were ever set. Engine is in a 550 replica with solid mounts.
    Paul Abbott
    Early S Member #18
    530.520.5816
  1. Solid Engine/Trans (915) Mounts
    By MoparBoy72 in forum For Sale: 911 Parts
    Last Post: 12-04-2011, 08:27 AM
  2. FS: Solid Motor/Trans Mounts
    By Mr9146 in forum For Sale: 911 Parts
    Last Post: 10-29-2011, 05:41 PM
  3. FS 911 Solid Engine & Trans Mounts
    By gled49 in forum For Sale: 911 Parts
    Last Post: 06-20-2010, 09:43 AM
  4. FS 911 solid engine mounts
    Last Post: 04-25-2010, 09:40 AM
