Results 1 to 8 of 8
Thread: Door seals - OEM or Old style repops
    Sep 2009
    Seattle
    Hi all,
    Does anyone have first hand experience in comparing the OEM style seals with the Old style repops as sold on by stoddard or Sierra Madre? Just wondering which way to go as I'm just reassembling after a bare metal repaint.
    Any input would be appreciated,
    Alex
    Do you mean other than the fact that they have completely different profiles?
    I got my original style repros from Sierra Madre, they fit fine. Installing any door seal takes a long time.
    Sep 2009
    Seattle
    Exactly - they seem entirely different from one another and I'm wondering if one does better than the other in terms of wind noise, install, actual seal, etc.
    Where I'm going to be judged in a concours I use the old style profile, or if originality is the point of a restoration, otherwise the newer profile is better.
    Senior Member Sepia911S's Avatar
    Aug 2011
    Chicago
    Why does it take a long time? Does the door have to come off? I will have the door seals on my '73S replaced this winter. What do I need to look out for?
    Candyce
    '73 911S, #9113301365
    Early S Registry #2027
    Quote Originally Posted by Sepia911S View Post
    No, the door stays on. But you have to fit the seal in the groove and make sure it doesn't end up bumpy, then make it work with the vinyl rear wheel arch panels, the black plastic threshold trim, the stainless threshold trim and the boot cowl carpeting. It has to be glued in so it doesn't come out. The corner has to be mitered with a razor very precisely and then glued so it doesn't separate. And so on and so forth.
    Sep 2009
    Seattle
    So is the general concensus that the newer style "OEM" seals are the right choice for a non concourse restoration? I've spent so much money during this process on parts that were sub standard that any help I can get from those with experience will save me big headaches.
    A related question - Do I need to install new carpet, headliner and piller vinyl before installing new seals?
    Here's some pictures from a couple days ago - It's coming back together bit by bit!
    Best,
    Alex
    Yes, all those interior pieces you mention are glued into the seal channel, so the seal is the last part to go on.
  1. Door Seals
    By sithot in forum Technical Info
    Last Post: 06-12-2023, 01:29 PM
  2. 914 interior door opener on 911RS style door cards
    By obrut in forum Technical Info
    Last Post: 01-09-2013, 01:55 PM
  3. Door Seals New
    Last Post: 08-31-2010, 01:31 PM
  4. WANTED: door handle seals for 1969 door handles
    By obrut in forum For Sale: 911 Parts
    Last Post: 05-15-2010, 06:15 PM
  5. door seals for SWB
    By mjmoran in forum Technical Info
    Last Post: 04-21-2005, 09:15 PM
